Question about Hayward Pool & Spa
SOURCE: heater temperature control buttons
The board is bad. The part number is IDXLCPA1930. Expect about a $400 replacement cost.
Posted on Dec 21, 2008
SOURCE: Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
Posted on Jun 14, 2009
SOURCE: hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
Posted on Jun 21, 2009
SOURCE: Hayward pool heater wont stay lit
Follow the troubleshooting guide on page 36 of this owners manual. It will walk you through problem solving... http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
Posted on Apr 22, 2010
SOURCE: Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Posted on Apr 23, 2010
Aug 24, 2014 | Hayward H400idl2 400,000 Btu Low Nox...
Oct 14, 2012 | Hayward H250FDN Low NOx Natural Gas Pool...
Nov 14, 2011 | Hayward H400FDN Low NOx Natural Gas Pool...
Sep 16, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
Apr 17, 2010 | Hayward H400FDN Low NOx Natural Gas Pool...
Jun 06, 2009 | Hayward H Series Pool & Spa Heater...
May 26, 2009 | Hayward H - Series 400 Heater Top for In -...
217 people viewed this question
