YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
- Change your needle and insert a newly wound bobbin every time you start a new project
- Use a size Embroidery Needle - size 90 for most projects
- Check the backside of your design - you should see alot more bobbin
thread than embroidery thread. If you don't see enough bobbin thread,
loosen your top tension. If the tension is set automatically, change it
manually.
- Your design might be the problem. Some designs have WAY to many
stitches. If you haven't already, choose several different designs with
different styles - for example, a monogram, a design that is mostly
satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
- Is the machine brand new, or new to you?
- Do you have your manual?
- Do you been embroidering by machine for a while, or are you just learning?
- Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
- How many total stitches are in the design you are trying ot sew?
- What kind of thread are you using (rayon, poly, sewing?)
- Did you buy the machine from a dealer, and if so, does it have a warranty?
- Have you taken lessons on how to use your machine for both sewing and embroidery?
- Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
