Question about Biostar Computers & Internet
I NEED DRIVERS FOR A POINT OF VIEW GEFORCE GT630 4096MB GRAPHIC CARD. IM RUNNING ON A CORE i5 PROCESSOR AND A HI-FI Z97Z7 BIOSTAR MOTHERBOARD. PLEASE HELP
Posted by Nkosikhona on
5 Related Answers
Anonymous
SOURCE: Motherboard doesn´t work
Biostar Ver 1 through 7 does not support a pentium dual core. They made a mistake in their printing in the booklet! Ver 8.0 will support it.
Posted on Feb 10, 2008
Anonymous
  • 7 Answers
SOURCE: graphics card problem
I have the 9600 GT - great card. You have to plug a 6 pin power supply directly into card (on the right hand side when it's installed), it can go AGP or PCI express, but PCI is better. Also NVidia released a new driver for it yesterday (nov 20th) which fixed some bugs in mine (dreamscene WAS a problem for the old drivers), so get that from the Nvidia site- support tab (driver is version 180.48). Also, if the card is allowing you OS to boot it should be fine (if no boot, you prob need to get newer mobo). Uninstall your old drivers, run a reg cleaner, driver cleaner, manually delete c:\nvidia, non-windows defrag and chdsk.....If thats no help to you then I suggest you directly ask beni-muer or world-vet, they are absolutely 1000 more times knowledgable than me when it comes to these probs.. GOOD LUCK.
Posted on Nov 21, 2008
Anonymous
  • 1073 Answers
SOURCE: I have a P5VD2-MX motherboard, currently I have a Geforce 7900GS.
Hi!
Since there is 1 PCI Express x16 slot you can use any PCI Express GPU, like Asus GeForce GTX 260 896MB PhysX CUDA, EVGA GeForce 9800GT 512MB PhysX CUDA, Gainward GeForce 9800GT 512MB PhysX CUDA or whatever you want as long as it is a PCI EPRESS card.
Good luck
Nic
Posted on Mar 22, 2009
Anonymous
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
Posted on Sep 05, 2009
Nandakishore
NANDAKISHORE
  • 304 Answers
SOURCE: I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
Posted on Oct 04, 2009
How many processors supports my motherboard p4m80-m4 biostar ? specially can it support dual core processor...??? also tell me about supported graphics card please help me>>>???
You have a very old motherboard here. It only supports the older AGP 8x video cards. Good luck finding one of those anymore that is worth the price, and don't expect anything you find to be new in box. This is probably where your HD video woes start, although the board was never designed for the higher frame rates that HD requires to be viewable.
As far as the processor goes, this board has the Socket 478 for Intel processors. There are no dual-core processors that are supported by this socket. Here is a link to an article that shows what processors are supported by the socket. Be advised, however, that depending upon the BIOS revision on the board, some of these may not work properly, if at all.
Socket 478 Socket mPGA478B
Really, if you want to view HD, it's time for a real upgrade.
Aug 24, 2016 | Biostar P4M80-M4 Motherboard
I wnt buy laptop but idk which1 bter and suitable for my software? any1 can help me pls?
For me easy;
1) The Dell Inspiron 15R i5 Notebook PC comes with an Intel i5 processor, model 2410M (2.3GigaHertz frequency rate),
It uses DDR3 at 1066MHz, (Why would you?), or DDR3 at 1333MHz, and up to 8GB's of it.
http://en.wikipedia.org/wiki/List_of_Intel_Core_i5_microprocessors#.22Sandy_Bridge.22_.2832_nm.29_3
It has Intel HD Graphics 3000 graphics built-in. (It's in the Intel Core i5 processor. It is Integrated Graphics)
Ummm, no.
2) The Toshiba Satellite L755-S5173 Notebook PC, comes with an Intel Core i5 also.
Model 2450M Intel Core i5 processor;
It comes with an Nvidia GeForce GT525M graphics chipset.
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_500M_.285xxM.29_series
A LOT better than the Intel HD Graphics 3000 GPU (Graphics Processing Unit), above.
From what I can see it is a graphics chipset soldered to the motherboard,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L755-L755D-L750-L750D/dismantle-laptop-3.htm
Click on the photo in Step 27. Bottom view of motherboard.
Look at the black Fan Assembly, and the copper curved Cooling Tube.
Go over to the far left of the Cooling Tube, to the rectangular silvery shape. Has 4 black screws in it. (This metal plate sits on top of the Processor)
In-between this rectangular metal plate, and the bottom of the motherboard, is the Nvidia graphics chipset.
Square dark green shape (Circuit board), with a smaller dark square shape in it. (GPU)
Means it isn't a graphics adapter card, and therefore not upgradeable.
Uses DDR3 Sdram (SO-DIMM) 1333MHz ram memory, and up to 8GB.
3) Lenovo G470 Notebook PC has an Intel Core i5, Model 2450M also.
UP to 8GB's of DDR3 Sdram (SO-DIMM) ram memory, at 1333Megahertz, too.
Intel HD Graphics 3000 is used also. (Integrated Graphics)
Ummm, no.
My choice?
The Toshiba Satellite L755-S5173.
Better graphics.
One of the things you ALWAYS look at for a laptop, because 95 percent of the time you cannot upgrade it.
(A LOT of laptop manufacturers state - Graphics Card, when the truth is it is not a replaceable graphics adapter card, as used in a desktop computer )
This means you are stuck with the graphics of the laptop, until you obtain a better one.
Regards,
joecoolvette
Apr 25, 2012 | Computers & Internet
Pciex reporting only 8x speed with two 570 graphics cards installed.
One card should be operating at 8X, and the other at 8X.
That's the way the Intel Core i processor works. There is no Northbridge chipset handling the Processor, Ram Memory, and high-speed graphics. The Intel Core i processor itself handles them.
(Quick-Path Interconnect. QPI)
When two graphics cards are inserted into the two PCI-Express x16 slots, the cards work at an 8X speed each.
More information on the Intel P67 motherboard chipset,
http://support.intel.co.jp/Assets/Image/diagram/p67_block_diagram.gif
More information on the Intel Core i7 processors. This info applies to all the Intel Core i models.
Core i3, Core i5, Core i7, and Core i9,
http://www.hardwaresecrets.com/article/535
Regards,
joecoolvette
Jul 05, 2011 | EliteGroup ECS Black Deluxe P67H2-A2 SLI...
Hi guys, i need some advice on setuping my new system. here is the spec of my new system: casing- collermaster HAF 912 motherboard- MSI P67A-GD55 processor- INTEL I5 3.1 GHZ ram- 4gb x 4 total...
YES THIS GRAPHIC CARD WILL BE ACCEPTED BY MSI P67A-GD55 BOARD..
BELOW SHOWN IMAGE IS A VIEW OF NVIDIA GEFORCE GTS 450
THIS CARD ONLY SUPPORTS TWO DISPLAYS AT A TIME
May 24, 2011 | MSI N450GTS-M2D1GD5/OC GeForce GTS 450...
Which laptop for 3d animation .use softwares maya,max ,video editing dell's config: Intel® Core™ i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA®...
dell\'s config: Intel® Core? i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA® GeForce® GT 420M graphics with Bluetooth (with WIDI) 4GB 1333MHz DDR3 SDRAM (1 x 4G) (operates at 1066MHZ for Core i5 processors) with increased RAM will work fine
Dec 16, 2010 | eMachines M6811 Notebook
We own a dell dx270 p4 it wont boot up should we just buy a new one or is this one worth upgrading and what is the biggest processor we can put into it.
darrinjensen all I can offer is my opinion, as can everyone else. The decision rests with you.
A) The best Processor that a Dell Optiplex GX270 can use, is a single-core Intel Pentium 4.
The best Ram Memory is DDR Sdram at 400MegaHertz. (PC3200)
This is shown by the fact that the Northbridge chip is an Intel 865G.
Supporting Data:
1) http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
2) http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
3) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[ The CPU {Processor} communicates through the Front Side Bus {FSB} to the Northbridge chip.
Think of an FSB as an 'Information Highway'.
Information {Data} goes back and forth across the FSB.
{Chip and Chipset are slang terms for I.C. Integrated Circuit}
The Northbridge chip determines what Processors are supported, what Ram Memory is supported, and High-speed graphics.
{High-speed graphics being AGP or PCI Express.
Not a graphics card installed into a PCI slot, nor Integrated Graphics.
Integrated graphics is also referred to as OnBoard graphics. ON the motherBoard. The graphics chip {GPU) is soldered to the motherboard. Not to a removable graphics adapter card. (Graphics card/Video card/Graphics adapter card, all mean the same thing)
The Southbridge chip handles the slower processes of a computer. Therefore also handling anything to do with a PCI slot, or Integrated graphics ]
A motherboard is the 'Building Block' of a computer. From it, all hardware components are supported.
Processor, Ram Memory, Graphics card, (Or Integrated Graphics), and so on.
What Northbridge chip is used determines a lot about a motherboard, besides the internal connectors used.
When buying a computer this is what you need to look at, for one.
Things have changed with the introduction of the Intel Core i3, i5, i7, and i9.
There is no separate Northbridge chip. It may be integrated into the CPU, or not used at all.
There is no FSB. It has been replaced with the Quick-Path Interconnect.
Intel rates their Processors with a star system now. The budget, or entry level Celeron is a 1 star. Pentium's are 2 stars. Core i3 - 3 stars, Core i5 - 4 stars, Core i7- 5 stars.
Point?
With the introduction of computer utilizing the Intel Core i3, i5, i7, and i9 processors, the computers that can use Intel Core 2 (Duo and Quad) processors are becoming VERY economical.
You may be able to purchase a desktop computer that utilizes an Intel Core 2 processor for around
$400 to $500. One that utilizes a comparable AMD processor for the same, or less.
And has Windows 7. (I know, do not start a sentence with And)
One example, (Not advertising for website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6326393&CatId=6
Another example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6738683&CatId=6
The Power Supply is probably what is bad with your GX270. Also, has it been cleaned inside on a regular basis as needed? {To include the Power Supply. A can of compressed air for computers is used. Power unplugged to computer}
Oct 24, 2010 | Dell GX270 P4 256/40/48X/XPP/NONE...
760 core i5 processor not working on 55tc mother board gives beep sound
dh55tc - i5 7series combination required additional graphic card
onboard graphics wont work. and for i5 6 series not required, onbord graphics work. http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DH55TC
Oct 19, 2010 | Intel DH55TC Motherboard
I want to buy a new rig , main purpose is to use for 3D Animation and Rendering(After Effects,Photoshop, Premiere,Maya, Nuke, Fusion Etc.)I have set a config in my mind Intel Based PC, But I need...
The processor is too weak - get at least an i5, best would be a quad core i7; the hard drive will be filled faster than you thing - bigger is always better; get some faster memories - at least 1666 MHz, 4 GB is bare minimum, get a 64bit OS and 8 GB for real performance; the power source is at the limit - for best result get one of 600W; as for the video card the best for photoshop is Nvidia Quadro CX, even ATI Fire will be better than any gaming card.
Jun 13, 2010 | Intel D865GBF Motherboard
Need advise for upgrating graphics card
GET THE NVIDIA G FORCE 8400 GT IT IS THE NEWEST CARD AND IT WILL RUN EVERYTHING YOU HAVE.
Mar 27, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Video drivers crash my Systemax out of XP
your video card is most likely overheating, either you are overclocking the video card or the video card's fan is stuck, jammed, broken ect...
Dec 24, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
53 people viewed this question
Top Biostar Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Davit Mamyan
Davit Mamyan
Roy May
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
