SOURCE: HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
SOURCE: have a laserjet 1300 connected to a netgear router
you have to assign port for the printer in the router and reserve static ip for it
SOURCE: hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
SOURCE: print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access
Piont: My Home Wifi (kaba)
Host : ip address of you
printer
user : Blank ( tried my windows username,no
use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
