Question about Home Fencing
Et 500 sliding gate motor when you press the remote it beeps then makes a click click noise and then beeps again but does not respond. can someone help me please
I replaced the batterg and still doing the same
Posted by Lorik on
5 Related Answers
chryslertech
mike ryner
  • 115 Answers
SOURCE: automatic sliding doors and lift gate don't always work
You need to go to the dealer and have them check the codes. The factory has a reflash for the sliding door and liftgate modules for this type of problem the codes it might have for this is INCOMPLETE POWER OPEN - EXCESSIVE HALL EFFECT SIGNAL the flash is resetting obstacle detection values. But you need to go to the dealer, this can be only one possible cause. I have fixed many vans that has had these 2 codes. There is a bulletin from chyrsler for this.
Posted on Mar 08, 2009
Anonymous
  • 52 Answers
SOURCE: when should I replace battery for Elite Robo-slide gate opener.
Sounds like its time to replace now!
Posted on Jul 02, 2009
GraemeSe
  • 28 Answers
SOURCE: Steps to program additional remotes for Centurion gate motor
hi
are the remotes sorted
Posted on Feb 23, 2010
Anonymous
  • 77 Answers
SOURCE: my passenger side sliding door is dead I tried all
You might try rehoming the door. Erase the sliding door DTC's by removing the No. 7 fuse in the under-dash fuse box and reinstall it. Then turn off the Main switch for the doors and make sure the ignition switch is in LOCK (0). Fully close the sliding door manually. Turn the ignition to ON (II) and then turn on the Main switch. Test the door operation several times. note: If you have an 99-04 Odyssey let me know the procedure is different.
Posted on Mar 12, 2010
Anonymous
SOURCE: I have bought an additional
Steps to Programming Centurion Nova Remotes
1. Unlock the motor cover with your Centurion Key, remove this cover.
2. Inside the perspex enclosure there is a small Receiver Board (approx size of a matchbox), identified by wording CENTURION CP9Z, also has the wording J1-Learn; J2-Erase.
3. There will be a small 'shunt' placed on one of the pins labelled J1, J2 or the centre pin - these are the 'Learn' pins.
4. Remove this shunt and place it over (or bridge) the J1 and centre pin together. The red LED Status light, to the left of the Learn Pins will illuminate.
5. Remove the new Remote/Transmitter from its packaging, hold down the required button once and the red LED Status light on the Receiver Board will flash once indicating that the button has been learned. As soon as the light has flashed, remove your finger from the button.
6. If further Remotes/Transmitters are to be added to the system, repeat step 5.
7. Ensure that you now remove the 'shunt' and place it back onto the blank or J2 pin - do not leave it bridging two pins.
8. Close the enclosure, place the motor cover back onto the motor and lock in place.
Posted on Nov 03, 2010
The manual override on my ET 500 does not work. Problem is I have no idea on what principle it works so I cannot even think about fixing it
Disengage motor from gate by using key to unlock latch and pull release latch back to disengage motor gear . Then side gate back
Oct 04, 2017 | Cars & Trucks
What has caused my ET 500-Plus motor to stop beeping
This error is not mentioned in the troubleshooting guide. As the beeping assists in confirming basic gate functions, it absence is detrimental. Lacking technical knowledge of this gate, I refer you to technical support for the company.
Technical Support
Sep 05, 2017 | Computers & Internet
Husqvarna wont idle k760 what do I need to do
Replace the air filters.
All cutoff saws plug air filters to the point they cannot breath. Do not replace just one, replace them ALL !
You might also need to replace the spark plug.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Feb 02, 2017 | Husqvarna Garden
I have an ET 500 gate motor. My neighbour's remote opens my gate as well when she opens her garage door. How can I change my ET receiver to prevent the neighbour opening my ET gate motor?
Most garage door openers and I assume gate actuators have jumpers or settings if computerized to change frequencies.
Both the remote and unit will have to be changed.
Larry
Aug 05, 2016 | Building Materials
Replacing 140 amp fuse in lexus gx 470
Replacing 140 amp fuse in lexus gx 470 - Fixya
www.fixya.com/.../t26021201-replacing_140_amp_fuse_in_lexus_gx_4...
24 mins ago - The battery in my lexus gx 470 needed to be replaced it was hooked up wrog and the 140 amp fuse was blown how do i replace the 140 amp ...
HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS ...
www.fixya.com/cars/t24496313-replace_140amp_fuse_lexus_gx470
May 24, 2014 - HOW DO I REPLACE THE 140AMP FUSE ON A LEXUS GX470CAN"T GET THE FUSE BOX APART TO UNBOLT THE FUSE - Dodge 1997 ..
Dec 25, 2015 | Lexus GX 470 Cars & Trucks
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
MY ELITE SL 3000 UL WILL NOT WORK WITH REMOTE. IT WILL WORK WITH THE LOOP. PROBLEM WITH BATTERY OR NEED TO REPROGRAM THE REMOTE, IF SO WHERE IS THE LEARN XMITTER LOCATED PLEASE HELP
Hi Mary, do you have more than one remote for the gate? Your remote needs to be paired with the gate receiver. Normally you need to push a certain button on the control panel to enable learning mode then you press the remote button you want to use. You will have to follow this learning process for your device. Please keep in mind that just any remote will not work with your gate, it needs to be on the same frequency and use the same modulation mode.
Hope this helps.
Oct 28, 2014 | Elite Sl3000 1hp Slide Gate Motor,...
Home Fencing Logo
2,440 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
ray gallant
Tom Chichester
Are you a Home Fencing Expert? Answer questions, earn points and help others
