Question about Frigidaire Ovens
SOURCE: GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Posted on Sep 24, 2007
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
SOURCE: Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Posted on May 29, 2009
SOURCE: kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Posted on Nov 08, 2009
SOURCE: Frigidaire model FEF352CATB has a F3 error code
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Posted on Oct 16, 2012
