Not much info here but SL could be the mode setting. Typically modes are SLEEP, ECONOMY and STANDARD. Standard maintains your set temp at all times even if it has to turn on outside of normal filtration cycle. Economy only heats during a filtration cycle, and sleep will only heat within 10 degrees of set temp and only in filtration cycle. This cycle is really only useful while going on vacation or other extended periods of non-use. Not sure how to help change modes without knowing what spa pack you have but you should be able to find the owners manual on line with a little research.
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Hope this helps.
US Parts Center
