Question about Toshiba Cameras
How does is the right setting of Toshiba refrigerator display setting
My Refrigerator GR.-NF417G is not working regularly,display setting is fleshly which language is Japanese. So i cannot setup right place.Plse help me .Thanks you
Posted by Kyaw Hein on
Andrew Taylor
    Top Expert:
  • Toshiba Master
  • 31,399 Answers
Use a smartphone with the Google Translate App on it and use the Camera feature. Point it at the display and it will translate what it sees. Look for Setup - Language.
Posted on Mar 02, 2017
My Toshiba Refrigerator, Model GR-W58UT. Please advise the ideal ON-OFF time of the Compressor and how to adjust the same.
There is no normal setting as the setting depends on ambient temperature which can vary. There is no time setting as it cools until the selected temperature.
Apr 07, 2018 | Refrigerators
Why the water pump is not pumping water?
HI SORRY THE BEST I CAN OFFER IS CALL THEM CAUSE I SUSPECT THEY CONTRACT OUT TO MANUFACTURER FOR FRIDGES THEY ARE INTO ELECTRONICS AND COMPETE WITH LG
Jun 20, 2014 | Refrigerators
MY LG REFRIGERATOR NOT GET COLD THE MODEL OF IT IS GR-G302JC
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Refrigerators
LG Model GR-B429BLQN not getting cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 24, 2011 | LG Refrigerators
I have a GE refrigerator model number PSC25SG SA SS which has Problem that in every couple days the freezer and the refrigerator display panels display out of their setting ranges. For example, the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 24, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
I just bought GR R72MD Toshiba refrigerator. When
definitely not normal. could be a problem with the reeds in the compressor, the noise you are talking about the gas circulating sounds very similar to water running through pipes. id say definitely a manufacturers fault. see if u can swap it with another
Nov 11, 2009 | Refrigerators
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
Jul 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Cameras Logo
91 people viewed this question
Top Toshiba Cameras Experts
Ekse
Lawrence Oravetz
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
