Question about Motorola Radio Communications
Motorola mh230r 1 works fine the other transmits but won't receive.
Posted by paul497 on
eradiostore
  • Motorola Master
  • 1,658 Answers
Check your programming. It sounds like you have chosen a code number in one radio and the other radio has code turned off (zero).
Posted on Aug 15, 2017
3 Related Answers
eradiostore
eradiostore
  • 1658 Answers
SOURCE: my customer has 6 motorola max trac vhf radios.
If this is a new install, it is likely noise from the vehicles electrical system scrambling the processor of the radio. Put a filter on the power leads and check your install.
Posted on Aug 31, 2009
Anonymous
  • 151 Answers
SOURCE: 18 miles max range but actual it can transmit and
The reason for this is due to various possible conditions. The first being obstacles in the operation range of the unit. IE> hills buildings trees ect. This can greatly reduce the actual distance the unit will work in. The 18mile max is probably a rating that would apply in the best opt. scenario. You would have to be on a flat terrain with no hills or valleys,no trees or buildings for the unit to reach the max distance. In dense areas of trees,buildings or uneven terrian you wont even come close to these distances. Second: any unit RF unit that is held in your hand or close to your body does cause the antenna to detune to various degrees the amount that it does depends on how well the unit has been designed. The more it detunes the less resonated frequence is recieved and amplified making for a weaker signal. In conclusion for the best long range reception be clear of as much surronding interference as possible and as high a possible above any elevated terrian
Posted on Jan 17, 2010
glenue
Bong Hermoso
  • 106 Answers
SOURCE: my motorola MH230R radios won't
Try to clean the contact point of the antenna of both the transceiver. There might be a foreign object which clog the signal to be fed...if the problem still exist. The possible reason is one of the transceiver has a defective amplifier circuit...
Call a technician to locate the repair the problem
Posted on Sep 19, 2011
Talkabout MH230R does not Receive or Transmit on channel, can just Transmit (only clicks when Recieve) when programmed 2 channels higher (i.e. all radios on 5-3, one is on 7-3)
Strange. Could it be any of the radios are from different countries? The channels are not worldwide. For instance, Canadian radios are on different frequencies than USA radios. They look identical.
Dec 30, 2015 | Motorola Talkabout MH230R 2 Way Radio
One of 2 set Motorola MH230R isn't transmuting ring or voice, but receiving is fine. All settings the same. What's I am missing?
Check your batteries. Transmitting (Tx) takes more power than Receiving (Rx). Also, check to see if you have the Qt filter turned on, if so, turn it and all other special features off (zero) and try using the radios in a very basic mode. If you cannot Tx or Rx with good batteries, and all special features turned off, you have a problem with one of the radios.
Sep 26, 2015 | Motorola MH230R Two Way Radio
Why does Motorola MH230R two way radios shut off automatically?
It's best to contact Motorola Solutions.
Http:www.motorolasolutions.com/support
Mark
Motorola mobulity
Aug 21, 2014 | Motorola MH230R Two Way Radio
Just bought motorola 4 Talkabout MH230R they are working fine except for one which is only receiving the voice and not transmitting anything. I tried Ringing other Walkie Talkie and thats not working and...
is it water proof? did you dip it in water?... if you did that's why the mic isn't working, the call and mic isnt working
make sure the channel is on the right channel for the walkie talkie
Mar 14, 2014 | Motorola MH230R Two Way Radio
Mh230r
Your radio is possible stuck in transmit, or has an internal issue. If you can get it into programming mode, check your programming. Also you might try trading the battery with a known good unit to see if it is simply a battery issue.
Here's a link to the user guide: http://shop.giantintl.com/Manuals.asp Choose your model from the pulldown.
Mar 04, 2014 | Motorola MH230R Two Way Radio
Mh230r
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Jan 04, 2014 | Motorola MH230R Two Way Radio
My motorola MH230R radios won't talk to each other. One receives, but the other doesn't.
Sep 19, 2011 | Motorola MH230R Two Way Radio
Won't transmit
First I would check the interference code on both radios to see if it is set the same. It is possible you have one set to zero and the other set to another number. This would cause the problem you describe. The interference eliminator is designed to block out transmissions from radios whose settings do not match it.
If all your settings are identical, and you have only 2 radios, it is not possible to tell which one has the problem. You either have one with no transmit or one with no receive. The only way to tell which you have is to get a 3rd radio involved, set to the same settings.
Sep 06, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Radio Communications Logo
490 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
