Question about The Audio Players & Recorders
Good Day! DStv I select a channel it moves to another channel. Sometimes scrolls through several channels rapidly the numbers showing on the bottom banner. Xtra View problem? thanks. Les
I suspect that my tenant has linked up a second decoder to his Xtra view.
Posted by Lesley Amble on
ray gallant
    Top Expert:
  • The Master
  • 68,373 Answers
Notify DSTV . they will come and cut him off if he is stealing signal
Posted on Mar 03, 2017
5 Related Answers
Anonymous
SOURCE: How to unlock TV channels if I forget the password
My TV Is Locked So How do I unlock those TV
Posted on Jan 09, 2009
dwlamborg
  • 16 Answers
SOURCE: Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Posted on Jan 20, 2009
Tommy_F
SOURCE: I live in Tahiti and
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Posted on Aug 05, 2011
jerok888
SOURCE: How to unlock e.tv in
How to unlock etv and scrambled channels on Mystrong Decoder
Posted on Feb 14, 2012
chimamy
SOURCE: Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Posted on May 28, 2012
Can anyone please tell me the best tenant screening service out there? I don't want complete screening services.....just the background reports and all; and don't even want to spend a lot?
'Not spending a lot' could cost you dearly. I read a great story in a magazine of a couple who went to live abroad for 2 years and left an agency to rent out there house. It was rented to a 'nice' man who said it was for his wife and son. What actually happened was that he added partition walls to various rooms and rented the house to 16 single students, some three to a room. The fire officer wasn't impressed.
Dec 19, 2015 | Cars & Trucks
Decode vin motoverse yamaha
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Get Yamaha VIN History Report Yamaha Vindecoder
VIN Decoder Motorcycle Identification Cyclepedia
Yamaha VIN decoder Lookup and check Yamaha VIN number and get build sheet...
https://itstillruns.com/read-yamaha-motorcycle-vin-number-4896367.html
Yamaha VIN Decoder
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 01, 2013 | Yamaha Motorcycles
Hotpoint Aquarius Extra WMA40 - Prewash light flashing and cycle not completing? The water level also looks to be very high? As tenants this machine has been installed (we suspect second hand) to replace a...
The water level on the Hotpoint WMA range of machine should be below the door, check out the error code definition at this site. You probably have a pressure chamber blockage or partial blockage. There are also workshop manuals for the Hotpoint WMA & WM machines which run through this sort of repair.
Mar 20, 2010 | Hotpoint WMA40 Front Load Washer
Decoder
I assume you are looking for a codec so you can play/view a DVD movie.
You can get a video Codec from this WEB site - click on this link :-
www.free-codecs.com/index.htm
Dec 19, 2009 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
Ariston A1636 1600 spin
The start/infinite switch is likely starting to fail.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Washing Machines
Cant play dvd and view 3d images
Go on www.hp.com then download and install the video card driver.
Oct 29, 2008 | Compaq Presario Notebook
Group forwarding after a delay
In memory block 4-1 for the extension's port, The Lkey for the CO line is lit green for immediate ringing, red for delayed ringing, and off for no ringing.
In memory block 1-1-77 you enter the CO's delayed ringing timer in seconds.
I wouldn't try and deal with seperating into tenants.
What I would suggest is in 4-19 restrict outbound trunk access (corresponding Lkey for CO line is lit to restrict)
For example:
Stations 1-4 would not be allowed to dial out on CO lines 5-6
Stations 5-6 would not be allowed to dial out on CO lines 1-4
This way Company A is not tying up Company B's CO lines for outbound calls and vice-versa.
Apr 09, 2008 | NEC Electra Professional ETW-16DC-2
245 people viewed this question
Top The Audio Players & Recorders Experts
Don Walper
Level 1 Expert
Larry Stiles
Larry Stiles
Michael Roth
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
