SOURCE: Link pins keep falling out on Ceramic Watch
They probably forgot to put the little locking barrel back in before hammering the links shut again. Some watches have the link, the pin, and a barrel that goes in the link before the pin is hammered in. If your watch needs this barrel then the pin will NOT stay in without it, no matter what.
SOURCE: TP LINK ROUTER SINAL PROBLEM
The range in free air is 100-150 feet with the original antenna. Since you have at least two walls of unknown composition and 30 feet minimum of space between buildings, it's unlikely. that a straight connection will work. You might consider a TP-Link access point and 2 larger antennas to send the signal farther.
http://www.tplink.com/products/product_des.asp?id=116
The antennas are at the bottom of this page:
http://www.tplink.com/products/wlan.asp
About $80 gets you the AP and a pair of antennas.
Carl
SOURCE: Have D-Link G604T router/modem and want to connect
Dear,
I think this will help you
http://www.tp-link.com/support/showfaq.asp?id=151
SOURCE: how to configure my tcp/ip TP-link access point
click on start
go to run
then type cmd
type ipconfig (in case of window)
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
