SOURCE: vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ??
3. If yes ..?
4. Then change the LOGIC BOARD or PDP
SOURCE: game screen freezes and there are white vertical lines on the tv
i dnt know about the vertical line but i had the same problemand i solved this by taking it to my nearest computer shop its as simple as that
SOURCE: vertical lines on plasma tv
Maybe is a lose contact in the conectors of the screen.
You need disconect the conectors, clean with isopropilic alcohol, and reconect the conectors.
SOURCE: vertical black line on the left side of the
it means the lcd panel is failing you will need a new one at a appox cost or 1500 dollars it is covered under warr
