SOURCE: sony megastorage 300 cd changer
Hi There are many things that can cause your problem, I can tell you the most likely ones, but I recommend you don't take the unit apart, as the mech. in a 300 disk changer is complicated & delicate, and you may just cost yourself alot more money than getting it repaired. The symptoms you sescribe can be caused by failing laser pickup, dirty laser lense (especially if you've done home renvations with drywall), split drive gear that moves the laser on the sled rails, or even a hair or piece of dirt in the gear teeth of that same gear. The unit will play fine, until it hits the tooth where the debris are, then it skips, or jumps back a bit and starts again until it hits the same spot. Also..badly scratched or finger printed disks will cause that, but that is the first thing most people check. I wish it was something you could repair yourself, but my best advise is to take it to a reputable repair shop, and hope it is not a bad laser, as that is a fairly expensive repair. Hope this helps, Good Luck!
SOURCE: audi gamma bose CC unit
I just took a 6 CD changer out of my 1993 Audi with a Gamma Bose CC as well as the adapter box. I am interested in selling it (I traded the car). If you are interested in the changer, let me know and we can exchange contact information.
SOURCE: 1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
SOURCE: cd changer won't play, load, or eject
Had the same problem on our 03 yukon (not the changer but the main head unit) - have a 3rd party waranty and they replaced it. You can get the part for less than 300$ and it's easy to install.
SOURCE: ford factory in dash 6 disc changer/radio
I have had the same problem with my Ford CD player, if you unhook the battery and let the entire system reset itself for approximately 10 min. or so and then rehook the battery and the CD that is stuck will either come out automatically or when you push eject. If you have not let the system off the battery long enough it does not work. Trust me I have had to do this more times than I can count.
