Question about Rangemaster LEISURE 55 & 110 FAN OVEN ELEMENT-CLASSIC
Rangemaster 55 leisure. My timer has stopped working
How do I repair it and what parts do I need
Posted by stella campion on
dik stukkien
    Scholar:
    New Friend:
  • 69 Answers
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Posted on Feb 17, 2018
5 Related Answers
Anonymous
SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
Posted on Feb 10, 2008
SOURCE: how to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Posted on Dec 08, 2008
Anonymous
  • 13 Answers
SOURCE: hello where will i find my serial number on the
Remove the drawer and the sticker will usually be on the right hand side of where the drawer goes in.
Posted on Nov 08, 2009
dervishy
  • 149 Answers
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me [email protected]
Posted on Mar 27, 2010
SOURCE: I have just moved into a house with Leisure
http://www.rangemaster.co.uk/Siteimages/Site_311/Pdf/ProfessionalPlus110DFOct08.pdf
User manual.
When the clock is first connected, the display flashes ( 0.00) and (?) alternately. To set the time, turn and hold the Timer knob to the clock symbol (?) and at the same time turn the Adjusting knob left or right until the clock shows the time of day. Remember this is a 24-hour clock. Let go of the Timer knob and it will spring back to the vertical, oven manual setting.
It is on page 6 of manual
Posted on Mar 28, 2010
Clock and ingnition not working on a rangemaster dual fuel stove
  • Hello David,
    when the clock does not work, the (left hand) oven will not work too I suppose.
    Often when the clock does not work, it is only the timer that does not work. In that case, the timer can be bypassed. The oven still works then, but without the timer and the clock will also work as a clock.
    So no timer.
    When it is an older rangemaster, and the ignition does not work, then probably are some wires leaking. I that case the power for the spark does not come to the burner sparkplug.
    But when all plugs do not spark then there are 2 possibilities I think.
    1 the ignitor is gone
    2 the ignitor does not get power
    I hope this helps, I wish you a good weekend, Dik
Mar 05, 2017 | Rangemaster Kitchen Ranges
Have leisure rangemaster 110 5487 ng cream. Have totally lost display for clock, timer etc. How do I replace this?
Phone Gas On Spares with model number 5487 followed by the following 6 numbers after 5487 and they will quote you for a replacement Programmer
Apr 11, 2011 | Rangemaster 110 (Gas) Kitchen Range
I have a rangemaster leisure 110 my timer was flashing but was able to reset it, now the clock is on auto showing 0.00 and using the two buttons for 6 seconds then pressing plus or minus nothing happens
how can I get to the clock, I want to disable the auto timer, I cannot seem to find how to get to the wires, the hot plate (warmer) needs to come out first I think but cant see how to get it out ..URGENT
Many Thanks
Oct 01, 2010 | Rangemaster 110 (Gas) Kitchen Range
I have just moved into a house with Leisure rangemaster 110 dual fuel, how do i change the time on the clock have pressed all knobs in various sequences, found the automatic, the timer but cannot move it...
User manual.
Mar 28, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
How to fit a flame failure device to rangemaster 55
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Instruction/Owners manual for a Leisure Rangemaster 55 Auto
I have the just moved to a house with this same oven. I can't find the exact manual online, but the timer/clock seem to work the same as this one..
http://www.leisurecp.co.uk/upl/15858-GR6CV.pdf
Oct 26, 2008 | Kitchen Ranges
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Rangemaster LEISURE 55 & 110 FAN OVEN ELEMENT-CLASSIC Logo
227 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Ekse
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
