Watches Logo
p
prabhakar wani Posted on Feb 27, 2017
I HAVE REPLACED TWO BATTREIS BUT ANALOG TIME IS NOT WOKING WHAT TO DO?
FIRST-CASIO 5056 WATCH NOT WORKING.THEN REPLACE TWO BATTERIS .TRIED TO START DIGITAL TIME SETTING NOW NO PROBLEM WITH DIGITAL.WHEN I TRIED TO ADJUUST ANALOG HANDS OF WATCH, AS PER MANUAL THEY ARE NOT MOVING AT ALL.NOW LET ME KNOW HOW TO DO THAT?
phoebe fedrick
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 27, 2017
phoebe fedrick
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
181
Points
10
Try to reset the clock and if it still doesn't work I think its broken.
1helpful
Casio watch has stopped working. there is nothing being displayed on the screen nor is the analog working.
probably needs a new battery,cr2016 should be, see videos on youtube on how to replace.What I found was connecting the AC pin to the top of the battery,which is the posive resets the watch after new battery in
Buttons and analog time stopped working
If the digital time is still showing, it looks like your watch has a defect. If the digital display doesn't display anything, the most probable cause is an empty battery. In both cases you should take it to the shop to have it repaired/the battery replaced.
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
My g shock ga 100 keeps resetting itself back to 12:00 and the analog doesn't stay synced to the digital i have had a new battery fitted and it still doesn't work any suggestions ??
Did you take your Casio to a pro or it was just a normal battery replacement service?.
I am asking because if a pro did it seems he forgot to reset your Casio watch when battery was replaced.
This is a must when you change battery on a Casio digital watch.
Take it again and ask for a complete reset, if they know what they are doing they will do as you ask without questioning.
Casio Watches
Jul 02, 2014 • Watches
I have casio 2747 analog issue i.e the Hand will stop after sometime even after replacing the battery.
Well there is a problem with the watch. You most likely have bad coil or movement that is draining the battery.
1helpful
Casio 3747 Wave Ceptor is 3 hours 52 minutes behind...
Paste this link into your browser and download pdf file:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3747.pdf
Read carefully about Radio-controled time keeping and other related chapters.
If after performing all the required operations your watch still does not work properly, you have some kind of fault in the Integrated Circuitboard and will need to seek for watchmakers help- probably an IC replacement.
Do not forget to rate, please.
1helpful
Wristwatch
Just replaced the battery so the analog (the hour hands and minute hand) works.Your watch has two batteries one for the analog and the other one is for the digital display,that's why only the digital is working..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Cant get Casio 4303 to enter receive mode
See: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
and go to the section "Adjusting the Home Position"
This is a "calibration" procedure to get the motor of the analog movement back to the home position of 12:00. This worked for me, after replacing the battery.
Note that in this procedure the hour hand does not move separately, but moves with the minute hand. So to get the hour hand to move, you have to let the minute hand spin a number of times until you get the hour hand up to twelve o'clock.
Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
