Question about KitchenAid Kitchen Ranges
SOURCE: Main control panel
need to have a service company check the bottom oven elements first, the replacement part has only a 90 day warranty on it. if it is the control again ???????????????
Posted on Apr 10, 2008
SOURCE: Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Posted on Jun 03, 2009
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
SOURCE: After a recent power interruption the Electronic
These electronic controls are very sensitive to power surges. I am afraid your control is now bad and must be replaced.
There are no fuses or reset buttons.
Posted on Nov 13, 2009
SOURCE: Model KDRP407HSS4. The display
Here is the main support page for that model showing the detailed schematic diagrams and the parts lists with prices:
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Range-Stove-Oven-Hood-Parts/Whirlpool-Parts-KDRP407HSS4.cfm
Double check the circuit breakers at the house's main electrical panel and ensure that you are getting the correct voltage at the oven's electrical supply outlet.
Also try pressing the cancel button or setting the clock time on the oven control unit.
If resetting the circuit breakers does not clear the PF error code fault condition, then you probably need a new Oven Control Unit ($200) which is labelled item 5 on the Control Panel Parts diagram.
If the unit is still under warranty I would contact your local service representative and arrange a service call. If the warranty has already expired, then unless you are confident and comfortable disassembling a significant portion of your oven to carry out a moderately difficult repair, I would contact a local appliance technician and have them do the work.
Thank you very much and good luck.
Posted on May 12, 2011
Jul 06, 2017 | Cars & Trucks
Oct 16, 2013 | Sharp R-1481B Microwave Oven
Jul 04, 2013 | KitchenAid Kitchen Ranges
Jan 02, 2011 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Mar 23, 2010 | KitchenAid Kitchen Ranges
Jan 07, 2010 | Smeg A42-5 Dual Fuel (Electric and Gas)...
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Jun 15, 2008 | KitchenAid KCMS145J Microwave Oven
Apr 18, 2008 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Jul 03, 2019 | KitchenAid Kitchen Ranges
152 people viewed this question
