SOURCE: putting the halter back together
Finally I found the instructions for assembly of the halter.....here is the link
http://www.hasbro.com/common/instruct/Furreal_Friends_Butterscotch_Reattach_Halter.pdf
SOURCE: put back togather
http://img107.mytextgraphics.com/photolava/2007/11/23/mx5184-48lorgeqx.jpg
check out this link for the spring location
hope this helps :)
SOURCE: It's been awhile since I have used my shampoo
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
SOURCE: water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
SOURCE: can i get detailed instructions to reassemble
Same problem here. Wish there was instructions online somewhere.
Hello Caron, thank you for your inquiry!
Based off the information you have provided you took apart the bottom panel of your Frigidaire dishwasher and need help reassembling it. I have attached a parts schematic of your dishwasher to help assist you further. Best of luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/5995552584.pdf
