Kumara Posted on Feb 26, 2017
How to reset Toshiba 256 copier total counter?
5 Related Answers
Andy Bebb
  • 62 Answers
  • Posted on Jan 08, 2008
SOURCE: sharp ar-5316
Hi, from memory, the secret test commands are: # I CA #, then 81 to reset main copy count.
Cheers
Andy
Anonymous
  • 62 Answers
  • Posted on May 11, 2008
SOURCE: toshiba 1360
Did you replace the cleanerblade?
Power off the machine, switch on while pressing 0 & 8, enter 200, then press the start button, the machine will run for about three minutes to adjust the Toner sensor. The machine will stop, press the interupt button to save the setting, switch off and then on.
If the older techies is reading this, please help to confirm.
Anonymous
  • 318 Answers
  • Posted on Nov 03, 2008
SOURCE: 4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Anonymous
  • 37 Answers
  • Posted on Mar 03, 2009
SOURCE: AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then # key
2.If the display turns off it means that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Aug 04, 2009
SOURCE: Reset the copier counter AL-1641CS
c photo c photo then screen is blank press 14
press print key then show 00 is ok
How to reset counter in toshiba studio230
You mast have acode at the right of panel
For example c400
Tell us what is the code to help you
3helpful
How to reset spanner indication in Toshiba e-studio 181
0-8 pressing and power on machine
251 and press start
you see your total copy counter
put a number over than this and press interapt button
switch off and on again
Resetting the counter on a Toshiba e studio 2500c
I reached the total print counter 109219 and want to re set.
E-Studio 3511 Color Copier written in the screen call for service total counter 372278, how can i solve this problem?
hello
we have like that message before in our copier also but the only thing i did is shutdown and start again and i reset the counter and it goes fine.
make hard reset remove all the power cable and plug again.
thanks
How do you get the total counter to print? When I log in under Administrator, I can print out department codes, but the total counter will not print. It will only show on the screen.
There is a counter button on the panel that brings up 4 squares. One of them is print out total counter. One button on the panel and one touch on the screen. Hope that helps.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
