Canon has a range of low-priced designs, comparable to other suppliers that supply printers as well as MFPs to home as well as small business people. The canon mx490 wireless setup is sure to set you back just over a hundred dollars. For a four-function device that provides printing, scanning, copying and faxing, that's not much, but it doesn't necessarily mean it's a great value. The Canon Pixma mx490 setup wireless offers no-frills printing, scanning, copying and faxing with a small black rectangle of 17.2 at about 11.7 inches and assessing just 13 additional pounds. A folding auto document feeder (ADF) contains 20 sheets and does not scan duplex like the tool's printer portion as well. The top of the MX490 is hinged when the glass scanning platform is raised.
SOURCE: How to change the ink cartridge?
1: Turn printer on
2: Lift up front panal (below scanner)
3: Wait for print head to appear
4: Remove old cartridge (push down & towards you)
5: Push new cartridge into position
6: Close panal & wait for the Printer to prime the cartridge.
If you are using a PC with check it works in the printer section of Control Panal
SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
SOURCE: IP1880 Canon PIXMA showing Ink absorber full
Pixma ip 1880 is full(solution)
1. first unplug power cable and usb cable
2. hold power for 1-2 minutes
3. turn on power
4. your printer should back to normal printing
SOURCE: how to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: I need a tool to reset my canon pixma iP4600 ink cartridges
I found the only tool I have seen at this url. http://www.patronenhandel.de/shop/index.php/cat/c13943_Canon-Chipresetter.html It is a German company, but I was able to order the resetter from them with no problems. It has worked very well, but was a little expensive. part of the problem was that the US dollar and Euro were not at a favorable exchange rate when I ordered. I didn't get any answers to my emails to them, but when I used there site to order, it took about a week to get the device. It is very simple to use.
