Question about Motorola Radio Communications
How to program a Motorola rdm2070d to a baofeng bf888s
Posted by Kristopher Hammer on
John L radiodude365
    Master:
  • Motorola Master
  • 570 Answers
The RMD has a set frequency list. Those are factory programmed and cannot be changed. Your baofeng can be reprogrammed to most frequencies.
Critical! First, make certain both are in the same band: Uhf or Vhf.
Make the list of frequencies you need both radios to use. If the RDM has it in the list, you are good to go! If it does not, and you must match the Bao, get a new radio. There are no mods or hacks for an RDM.
Posted on May 21, 2017
3 Related Answers
eradiostore
eradiostore
  • 1658 Answers
SOURCE: program motorola rdm2070d
The RDM2070D is non-programmable. It operated on pre-selected frequencies. (This radio belongs to a major corporation, and is not intended for use outside their company.)
Posted on Oct 12, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: I need to fix the frequency to match my other
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Posted on Nov 08, 2009
MotoGenius
Motorola Mobility
  • 3100 Answers
Mobile Phone and accessories
    Verified Fixya Pro
    SOURCE: On my Motorola RDM2070d which is positive and which is negative?
    Contact Motorola Solutions. Www.motorolasolutions.com/support Mark Motorola Support
    Posted on May 16, 2015
    Can a pair of Kenwood TK 3160 work with Baofeng BF888s I have a Baofend and another coworker has the second Baofeng.Our shipping office bosses have Kenwood TK_3160 can they share channel 7
    Here goes. Yes, your Baofeng Ham radios could be programmed onto a business band channel. Yes, it could transmit. BUT, ham radios do not meet the stringent requirements that Business Band radios do. This refers to channel spacing, interference and a long list that Business radios are required to have to make operation legal. Therefore, your Baofeng makes a great scanner. Business band frequencies are to be used by radios meeting these stringent requirements in order to prevent interference. Failure to follow the FCC Rules could result in a hefty fine. Didn't you wonder about the price difference?
    Apr 15, 2015 | Kenwood Programming Cable Tk2160,tk3160...
    How can I get my Motorola CLS1110 to talk to my Baofeng BF 888s?
    The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. [email protected]
    Mar 01, 2015 | Motorola Radio Communications
    What radios are compatable with motorola rdm2070d
    The Motorola CP110 MURS VHF is a nearly identical radio. Most 2 watt programmable VHF radios are programmable to the MURS frequencies.
    Jul 20, 2014 | Motorola Radio Communications
    Channel voice announcement
    go into the programming software, settings & see if there is an option, if not it sounds like the radio is on its last leg
    or at least try to a factory reset
    Apr 23, 2014 | Baofeng BF-888 S UHF 400-470 MHz Portable...
    Get Motorola CLS 1110 to work with my Baofeng UV5r
    Dear sir,
    pls diable Interference eliminator code on baofeng,, & try the same
    Dec 14, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
    I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
    Nov 03, 2009 | Motorola XTN Series Pro Two-Way Radio...
    Program motorola rdm2070d need to program
    Oct 12, 2009 | Radio Communications
    Radio Communications Logo
    621 people viewed this question
    Top Motorola Radio Communications Experts
    eradiostore
    eradiostore
    Jane
    Level 1 Expert
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
