Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore 790 I have a Kenmore electrical stove/oven. A few days ago it a fuse blew and it turned off. After opening the oven I discovered that one of the wires to the burners was burnt and disconnected. I replaced the burnt portion and but the "Element on" light keeps coming up without anything being on. If you know why it could be coming on and/or what to do we would greatly appreciate it. Thanks so much! Cathie & Dan
Posted by delbigman on
  • Anonymous Mar 31, 2014
    Element light always on
Anonymous
  • 213 Answers
When the wire to the element burnered it shorted to ground blowing out the switch. you should still be able to use the element but to get the light to operate normally youll have to replace the switch for that burner
Posted on Nov 20, 2007
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
My question concerns a Kenmore glasstop electric oven (model #790.95200100). While operating the oven at 450 degrees and the back right burner at level 5, I heard an audible "pop" and saw a flash of light...
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
Sep 14, 2009 | Kenmore Ovens
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
790/9546/1990 Kenmore Electric Range
Here's a link that you can order your manual from: http://www3.sears.com/. Good luck!
Jul 17, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Kenmore 790 Oven Locking mechanism problem
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
284 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
