Cars & Trucks Logo
E
Elaine C Campbell Posted on Feb 24, 2017
Where is the fuel reset button on citroen nemo van 12 plate please? If there is one you can access of course.
2answers
2012 Citroen Nemo Multispace 1300 HDi. 75. Diesel. Change engine oil warning keeps coming up on my control panel. How do I remove or reset it Please . Phil
With ignition key off .. Hold right button down (2 buttons within the instrument cluster) Turn on ignition.. but not engine.. Watch for countdown till zero.. Release button.. All done....!
2answers
How do I remove the Change Engine Oil light on my Citroen Nemo 13 HDi multispace diesel car??? No clowns Please Phil
My Citroen nemo won't start
The most likely being a faulty EGR. take it to someone who can hook it to a diagnostics computer and find out what exactly is going on
Reset oil change light on citeron nemo 2011
Reset oil light after service... that is very important. And don't skip the oil change either.
1-turn on the ignition key,
2-press the gas pedal and hold it,
3-press the brake pedal 7 times without relesing the gas pedal,
4-keep pressing the gas pedal for 60sec.
5-Release the gas pedal and turn of the ignition key,
6- Wait for 60sec.
Then turn on the ignition key and start the engine. Check if the service/oil change light turned off.
That's it. Worked on my 2011 nemo van.
Cant open fuel filler cap on citroen nemo
Sounds like a vapor lock. disconnect a hose on the filler neck if you can or try to relieve pressure in the tank.
Top Citroen Experts
Thomas Perkins
Thomas Perkins
 Mikey
Mikey
Jonathan Buck
Jonathan Buck
Are you a Citroen Expert? Answer questions, earn points and help others
