SOURCE: Copy and Paste
a virus will not have anything to do with copy and paste. (i know, i make them) but it will make problems with other things, but since copy and paste is the problem, then the virus is not causing it. what you need to do is go to start>settings>control panel>keyboard. sometimes your problem is caused by a setting in the keyboard area getting turned off by a computer crash, unsafe shutdown, etc. if there is nothing under this category that sticks out to you, then try the "system" icon under the control panel. look for a copy and paste tab and look to see if it is unchecked. if none of this helps, let me know
SOURCE: Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
SOURCE: M. Works won't let me paste anything onto document f/the Int.
After copying the contents you need go to edit on microsoft works and click on paste special. A small window should open asking you to select from three options. Click on unformatted unicode text then click ok. That should do it. Although italics and bold letters come out as regular print like the rest it does paste all that you've copied. This usually happens when you haven't updated your internet. After updating mine I no longer needed to do this process again.
SOURCE: ' file integrity violated' error message.. copy problem
A message display as file integrity violated display when i try to copy or move the file
SOURCE: The finished copies fall to the floor. Isn't
On the left side of the output tray, U shall find paper tray extender that have to be pulled out to stop falling paper to the floor.
