Question about Weather Channel Measuring Tools & Sensors
I have the weather channel indoor outdoor thermometor and the outdoor temp and humidity are not showing up on my wall reader
Posted by don turczyn on
Andrew Taylor
    Top Expert:
  • Weather Channel Master
  • 33,376 Answers
With mine, this indicates that the battery needs replacing on the INDOOR unit. For some reason they don't pick up the signal from the transmitter. I use batteries 3 to 1, indoor to outdoor.
Posted on Feb 23, 2017
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
Oct 02, 2018 | Acu-Rite Acurite Wireless Weather...
The weather channel how do I reset the outdoor temp?
  • Remove all batteries from both units
  • Install known-good batteries in outdoor unit. Allow time for outdoor unit to initialize and begin sending data
  • Install batteries in indoor unit. You should see outdoor temperature displayed
Jun 04, 2018 | Weather Channel Measuring Tools & Sensors
I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Apr 01, 2018 | Measuring Tools & Sensors
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
Replacement has to be done in a certain order.
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Dec 13, 2016 | Measuring Tools & Sensors
Will not transmit outdoor info. Batteries good- LED lights. Monitor shows indoor temp only.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
May 23, 2015 | Measuring Tools & Sensors
Outdoor temperature reading shows -40 with wind chill -62. Outdoor temp is in fact +45.
We would recommend a hard reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac, and then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall battery into the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Mar 17, 2015 | Chaney Measuring Tools & Sensors
Is there an online manual for Springfield 91756 Wireless Thermometer w/Indoor/Outdoor Temperature & Humidity
Yes. Took awhile to find it, but here is the link: https://docs.google.com/gview?url=http://www.weatherconnection.com/manuals/91756.pdf&chrome=true
Aug 07, 2012 | Springfield Measuring Tools & Sensors
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
BIOS Digital Wireless Thermometer 312BC SETUP INSTRUCTIONS
I have a BIOS wireless indoor/outdoor thermometer. The indoor base unit doesn't display the outdoor temperature - it is blank - however the other temperatures - humidity, indoor temp, etc., are displayed, What is the problem? We have misplaced the manual so we don't know what to do.
Aug 28, 2010 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
1,711 people viewed this question
Top Weather Channel Measuring Tools & Sensors Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Weather Channel Measuring Tool and Sensor Expert? Answer questions, earn points and help others
