Question about Vizio Televison & Video
What do I have to do to hookup a headphone to my 60 in vizio TV?
Posted by Efraim Gonzalez on
richie46
    Top Expert:
  • Vizio Master
  • 12,962 Answers
Without opening set, easiest thing you can do is hook up a small receiver to the audio outputs of tv and then plug your headphones into the headphone output of receiver. And when not using the headphones you can always hook up some external speakers to the receiver - they will always sound better that the speakers that come with the tv.
Posted on Feb 23, 2017
Hookup vizio vsb207 soundbar to tv with xfinity cable.what is the wiring connection
You will need to hook the TV sound bar system to the Variable Audio output jack on the back of the TV.
Oct 26, 2016 | Vizio Televison & Video
How do I connect RS 120 headphones to Vizio M320VT TV?
Probably yes, connecting the RS transmitter to the composite audio output jacks (L/R) on the back of the Vizio TV.
Dec 26, 2014 | Sennheiser Audio Players & Recorders
I was given a 26' GFM LCD TV that has a popping
A sound bar fixed that on my 60" Vizio. But in your case the sound bar may be more valuable than a new TV.
Jan 14, 2018 | Televison & Video
How do I hook my Bose up to my vizio HD tv?
I have a Bose headphone and a Vizio HDTV. How do I hookup the headphones to the TV?
May 01, 2011 | Bose Wave Radio
The vizio e322vl headphone jack is not documented by Visio. There is an "Audio" spot next to "RGB PC" and I tried various jack sizes b none works. If you have a soulution, can you...
that audio jack is input only it is stereo jack to connect from the comptuer to the tv when using the RGB input. most headphone jacks if they are there would be on the side of flat panel tvs. otherwise the audio output may be digital(optical) or normal rca (red and white) that you can hookup to the headphone system.
Dec 23, 2010 | Vizio E322VL 32 in. LCD TV
I have new RCA model VHP141 Headphones but will not work with my new Vizio TV. Where do I plug them in the TV?
Visio might not have a headphone jacks at all! Look around your set and, probably you won't find jack marked as headphone. You might need to use wireless headphones, what have an rca plugs and connect them to audio monitor out on your tv set.
Alex's TV Service,
Philadelphia, PA 215-806-5980.
Jan 21, 2010 | Vizio VO47L 47 in. LCD TV
Connecting my inspire 5.1 to use with my sat/tv system
radelle1967,
I had originally bough these speakers for the sole purpose of connecting them to my 26" LCD Vizio television. I quickly realized that these speakers were not made for a television, so I just kept them connected to my desktop PC.
However, one day I asked my buddy from college to look at them and see what he thought. It took him a while to figure it out, but here is how I have them hooked up.
I can not guarantee that this will work on any other television set, but it does on mine. On the back of my Vizio television there is a hookup called "optional audio," which is located beneath the yellow, red, and white hookups. I hooked a 3-way headphone splitter into the "optional audio" hookup and then plugged the three cables from the speakers into the splitter.
Hooking up your speakers like this works very good and the sound is equally distributed between all speakers. However, there is a setting on my television under the sound menu that enables you to turn "surround" on. I had been told that by using a 3-way headphone splitter I wouldn't be able to get true surround sound, but turning on this option on my television actually allows this to be accomplished.
Hope this works for you. I purchased the 3-way splitter at radioshack and it was under $10. If your television does not have an "optional audio" hookup, you could probably try an RCA connector with just the red and white hookups that split into one and then connect the 3-way splitter to that.
Jul 28, 2008 | Audio Players & Recorders
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Televison & Video Logo
37 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
