Question about Sanyo DP32746 32 in. LCD Television
Hello, I have a Sanyo DP32746. I replaced the power supply, but atransformer on the new used board is buzzing. Don't want it to go bad again. Something else causing the boards to fail. Help please.
Hello, I have a Sanyo DP32746. The tv was going into power fail mode so I did some troubleshooting. I narrowed to the power supply board and I bought a used replacement. The tv now is working but the transformer at t605a is buzzing. When I disconnect the inverter connector to the backlights it stops. Can you tell me how to proceed and what the problem might be? My thoughts are the bulbs might be going bad, drawing to much current and that's what might of killed my last board. Btw, the last board did have some bad caps. A little bulging on the tops and they tested out of circuit as just a little less than 20 percent tolerance to their specified values. The inverter connector pins read: pins 1-5= 23.8V, pins 6-11=0V, pin 12=4.9V, pin 13=0V, pin 14=5.8V.
Posted by Harry Foster on
    Top Expert:
  • Sanyo Master
  • 76,587 Answers
SMPS transformer on board is bad. It has core loose.
Posted on Feb 23, 2017
Have a sanyo tv. After power fail tv comes on by its self the next morning. why
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Aug 10, 2012 | Sanyo DP32746 32 in. LCD Television
Light hit close to the house tv went off know the green light just bliks
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem.....
Oct 15, 2010 | Sanyo DP32746 32 in. LCD Television
TV turns off by itself(not sleep mode) usually turn back on sometimes unplug & try again in 5 min.s
This problems is the cause by the power supply board is dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo DP52449, tv getting power but no display
When DP52449 (chassis 01 - that is important!) does not power on and the front LED flashes every 15-20 seconds you have a faulty main board, which you need to replace or get serviced.
We presently do not offer replacement boards, but we do offer repair services for them at
http://www.coppelltvrepair.com/p/59/sanyo-dp52449-p52449-01-main-board-n7ke-repair-service
You may also be curious to read the article we wrote back in July 2012 on a problem that sounds exactly like yours and which lead to the service offerring:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
Hope this helps!
Feb 20, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 screen black no sound screen flashes when turned on
Hello, I just posted this to another user's question, and you might find it useful, too.
I have a pile of these in my shop. Unfortunately and usually, a backlight lamp is bad, and the inverter board is damaged when it goes out. The backlight lamps are sealed inside the panel, so the usual method of repair is to replace the panel.
If you turn the lights off in the room, then turn the tv on, you will probably see a momentary flash of light from the backlight trying to start up. The lamps can be replaced, but the option is not really cost effective given the amount of time it takes to replace them/very delicate nature of the lamps/availability of the lamps/cost of the lamps. Replacement panels might be available, but you'd have to use a TV shop for reference or call Sanyo directly.
These units also have a history of power supply heat damage, so if you don't see the momentary flash, it could be the power supply. But the momentary flash is the dead giveaway.
I hope this helps you...
Dec 10, 2008 | Sanyo DP32746 32 in. LCD Television
Inverter opertion
Hello davidweldon,
If the inverter board is bad, I would suggest that you replace the whole board unless you have a SMD (Surface Mounted Device) rework station, and a background in electronics. I have worked on TVs where people have tried to remove SMDs and it never is an easy thing to do, so I would again suggest that you replace the whole board, because all of the components are SMDs.
Now as to your question, I have seen on these sets the majority of the time it is a driver transistor that goes bad.
I hope this helps,
Thank you,
Shuttle83
www.electron-age-technologies-llc.com
Nov 12, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 - No picture or Sound
Damage is in the power supply. I am an authorized tech for Sanyo, and in the Chattanooga TN area. Contact Sanyo at 1-800-877-5036. At the prompt hit the 0 key, and then ask for customer service. They will be more then happy to assist. If your set is to old for warranty service, and you wish to repair yourself, check out the site www.shopjimmy.com, they can provide functional pwb's for a fraction of the cost of new.
Jul 14, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 Power Supply
Yes replace the power section of the tv.
Jul 13, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
Top Sanyo Televison & Video Experts
Mike
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
