Question about Precor Exercise & Fitness
I have a precor 956 and the display will not light up. the powerboard has a flashing red light....any ideas
Posted by Keith Glenn on
3 Related Answers
coupmadd
  • 7 Answers
SOURCE: intermittent
You probably have a worn deck and running belt.
Posted on Apr 07, 2009
Anonymous
  • 79 Answers
SOURCE: err22 showing.How can I start?
The speed sensor is a hall effect sensor that emits a pulse when a flywheel lobe passes between
its transmitter and receiver. The speed control circuit processes the pulse train emitted by the
speed sensor. The speed sensor signal is a real time representation of the operating speed of
the treadmill. The speed control circuit compares the real time speed (speed sensor output) with
the speed that it expects the treadmill to be operating at and acts accordingly to control treadmill
speed or initiate an error code sequence, if necessary. Typically, if a problem exists with the
speed sensor the drive motor will operate (perhaps only briefly) before a speed related error
occurs (errors 20-26).
1. Set the treadmill circuit breaker in the “on” position. Using a DC voltmeter, measure
the voltage between terminal 3 of J2 (green wire) and terminal 4 of J2 (black wire) on
the lower PCA. Slowly, rotate the drive motor flywheel. The voltage should read
approximately 5 Vdc when a flywheel lobe is between the speed sensor “legs” and
approximately 0.25 Vdc when a flywheel lobe is not between the speed sensor “legs”
2. If the voltages in step 1 are correct, go to step 5. If the voltage in step 1 is 0 Vdc or
significantly low when a flywheel lobe is between the speed sensor “legs, continue with step
3.
3. Measure the voltage between terminal 1 of J2 (red wire) and terminal 4 of J2 (black wire) on
the lower PCA. The voltage should read approximately 5 Vdc.
Flywheel
Speed
Sensor C954, C956 Treadmill
Page 1-24 Page 24
4. If the voltage is missing or significantly low, disconnect the speed sensor plug from the lower
PCA. Measure the voltage between pins 1 & 4 of the J2 plug on the lower PCA. If the
voltage is approximately 5 Vdc, replace the speed sensor. If the voltage is missing or
significantly low, replace the lower PCA.
5. At this point the speed sensor output is good, but a speed error occurs. There are two
potential causes for this condition. They are upper PCA or lower PCA. There are no good
means of troubleshooting these components other than substituting known good
components. Replace only one component at a time. If the component that you replaced
does not correct the problem, replace the original component. Try substituting the lower
PCA first then the upper PCA, if necessary.
tips extracted from the technical manual Precor956
Posted on Sep 14, 2010
Anonymous
SOURCE: on my Precor 956 i the Stop Key prompt appears
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Posted on Dec 07, 2010
When push quick start button, why does it display Erro 30 and doesn't run?
Hi There....This is a great message for ALL PRECOR 956/966 owners. This failure usually relates to a "communications" error between the upper and lower electronics. This particular failure is a direct result of a failed IFT drive module, or the lower drive "box" that is made by Advanced Drive Technology. The brains of this lower controller has failed and cannot "talk" to the upper board anymore due to several failed parts inside this box. You are lucky to have this failure arise over a fatal blow-out. Now replacements thru Precor or a distributor will be $550+ and are usually low stock items at places, but you can get repairs and exchanges of this Precor IFT drive by emailing gregATbuyfitnessrepairpartsDOTcom for much less than all other vendors. Currently these IFT drives are 380 exchange and 199 repair and turnaround is one day. Good Luck!
Feb 11, 2016 | Precor 956i Experience Series Treadmill...
No power, when I turn the switch on, the power lights do not display
Look on the back for a reset button, it could be a small red button the size of pencil lead protruding slightly, push in on it. It could also be located in side a small hole the same size use a tooth pick or something none metallic to push with...
Jan 09, 2014 | Precor EFX 556 Elliptical
The belt on my Precor C966i treadmill is not running and the display is flashing an "Error 22" message - what's the problem?
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
Dec 24, 2010 | Precor C966i Treadmill C 966i
On my Precor 956 i the Stop Key prompt appears
Oct 24, 2010 | Precor 956i Experience Series Treadmill...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Intermittent ''error 27'' fault / PRECOR C 956 treadmill
Apr 07, 2009 | Exercise & Fitness
Philips lcd 37pf9431d/37
finally got some help from customer service ----
the code flashing one then two red lights is for an upgrade of the software ---- you can go to their website and download a current fix to that problem onto a thumb drive----
\the power problem is caused by a bad power board--- you can replace them for any where from 130-330.00
dont need a service tech - take off cover and easy to replace---can find part on parts store.com for philips televisions --- used is about 130 and new about 330 -- used is a refurbished unit and works just as good as the new one
Feb 18, 2009 | Philips 37 in. LCD TV
GE Microwave
sounds like either a powerboard or control board is sending erratic voltage or no voltage to the table motor and possibly the light.
May 29, 2008 | Microwave Ovens
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Epson EMP-74 - Blinking Red Light
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
Apr 15, 2008 | Epson EMP-54 Multimedia Projector
Exercise & Fitness Logo
142 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
