SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
SOURCE: Electrolux front load washer door won't
First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
To do it, turn
off power, unplug at the mains. Drag the machine out so you can see
the back. Remove the 2 screws that hold the top on, pull back or tap
the top forward (depending on the model) to unclip it. Peer inside.
You will see the door switch inside the chassis exactly in line with the
door handle on the outside. See if you manually make the mechanism
release, or if you have a stubby philips screwdriver, you can probably
unscrew the switch complely.
Keep us updated.
SOURCE: The door is jammed on my LG Intellowasher
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
