Motorcycles Logo
Heerman Sanip Posted on Feb 21, 2017
My gilera seems to have voltage drop and cause my engine to cut off when i press my brake.
Greetings! I have a 2009 gilera runner 200st. With an engine temperature halfway on the gauge and on idle while waiting for a green light in an intersection, the rpm would drop as it seems to be runni
Clean plugs new fuel new battery. If you change one thing at a time you will know the problem. Lasts seasons fuel is the biggest culprit then it clogs up the plugs and delivers. Just dump the fuel.
2helpful
I have mayfair freerider and every now & then it stops then goes again there are no green light flashes.
hi, does it just cut out ?, if so there is one fault that can cause that, worth checking, try pressing the lever in the upwards or downwards direction while going along, if it doesn't cut out , the throttle pot needs replacing ... it's worth also checking the battery and controller connections making sure they are a good fit and tight...
Other causes:
Battery voltage dropping too low...
Brake breaking down..
Regards
Rob
www.gewizrepairs.co.uk
1helpful
2answers
Gilera runner 125 st 2008 cuts out by arcing
coil lead plug cap needs replacing , no shield to protect spark plug from getting wet due to weather/water splash. electrical spray lubricant requires from damp start problem
1helpful
Hi, My brake light on my Gilera cougar seems to be constantly on. I've only just bought the bike so not sure if it turns off when riding and stays on when parked. Possibly the front switch on the...
could be either switch at fault, start by pulling the wire connectors off the rear switch to see if the light extinguishes, if so its the rear switch, if not its the front.
2answers
Part of the engine that connects to bk wheel
u are better off replacing the whole engine bec in my exsperince u will spend around £200 pound fixing that u could pick up a another gilera runner engine for £150-£200 from ebay etc
1helpful
When i press the brake pedal and see the voltage drops
The voltage drops because the brake lights are lighting. It is common when idling or engine rpm is low
3helpful
2answers
Gilera runner sp50 - engine turns over but does not start
you went through the electric. system, now check fuel supply filter, tank, valve carb bowl for dirt
Gilera 125 vx 04 modal cuts out when reved up
fuel starvation you need to clean the carbs bud
2helpful
2answers
Gilera 125 xv engine cuts out when reved up
Carb needs cleaned and possibly rebuilt.
Please rate this solution.
Top Gilera Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Gilera Expert? Answer questions, earn points and help others
