Question about XO Vision Car Audio & Video
I have a XO Vision X406NAV that came with my 05 pathfinder. The touch screen doesn't work and there is a lock on screen that I can't figure out how to turn off.
Posted by Kyle on
5 Related Answers
Anonymous
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
Posted on Dec 17, 2007
Anonymous
SOURCE: XO vison styler x120aud2gb
i have the same probelm and i will try to contact the company. the stupid part is i used the software that came with the player.
Posted on Jan 01, 2008
Anonymous
  • 3 Answers
SOURCE: XO Vision MP3 player-problems downloading TV shows
Um hey, I have a Lyra MP3 player, I can't download videos but I have gotten music on it. When you download your music, it goes to a certain folder in your computer, it's up to you to find it. All that I did was copy/paste that to your MP3's folder. If that doesn't work I am really sorry.
Good luck,
Shannon
Posted on Jan 02, 2008
Shadow1989
  • 408 Answers
SOURCE: I am getting a white screen when I turn on the car
ok, the issue is that the lcd liquid needs time to warm up.  I found this out in my car here in Minnesota that I would see a white screen, which is the backlight.  The liquid that causes the display or colors was cold and thick.  Leave your car warm up to a good temperature and then try it out...should work.  Its a known issue with them, not much you can do about it except give it time to warm up.  If yours has a removeable screen like mine, take it inside with you at night.
Posted on Mar 07, 2009
Anonymous
  • 3 Answers
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Posted on Apr 06, 2009
How to display the clock on xo vision xod1760bt
The graphics aren't the best, pretty simple nothing fancy but the videos look pretty good. The deck has a lot of features and has surprised me so far. It has a clock adjustment but it doesn't display a clock in any screen. I believe it is a deck that is worth the money, even the three extended warranty only cost me 28 bucks. I haven't had it that long and I read in previous reviews that the longer you have it is when you start having problems, I hope not but if so I will just take it back. I would recommend it to anyone that is looking for a in dash TV but doesn't want to spend a lot.
1helpful
Replacement screen for xo vision 1742 deck
Model LCD 7'' :Innolux AT070TN07 + Touch panel (unknow)
1helpful
Can you text with the ematic 8gb touch screen?
Through my research I can not find any evidence that you can text on the XO Vision Ematic EM108VIDB .
It's noted feature is a FM Tuner
Xo vision XO1943BT
CHECK YOUR WIRES AT THE HARNESS WITH A TEST LIGHT TO BE SURE YOUR GETTING POWER TO THE HARNESS.AND A GROUND AS WELL. ANOTHER WAY TO CHECK IS TAKE THE UNIT OUT AND CONNECT DIRECT TO THE BATTERY UNDER THE HOOD
XO Vision XOD1736
disconnect the orange wire <illumination>wire
1helpful
5answers
E- brake bypass
Thanks for everyone's help. The bcar screen actually is the backup camera screen which is activated by the orange wire and when I turned on the lights, it got activated. I disconnected the orange wire and everything is fine. When I get a backup camera I'll connect that wire to the backup lights so that it will come on whenever I put the car in reverse. You are right that their manual is not very clear at all. I called their tech support and they couldn't help me trouble shoot the problem either. The unit is functioning perfect now but my next beef is that you can't change the XO vison default screen when a cd is playing. It would have been nice if you can scroll some jpeg shots of anything else besides looking at the xovision logo. I guess I can't have it all for $340 so, I'll stop whinning.
1helpful
2answers
Car Audio & Video Logo
Top XO Vision Car Audio & Video Experts
ADMIN Canada
ADMIN Canada
ray gallant
Relax
Relax
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
