Samsung UN55HU7250 Curved 55 Inch Ultra Logo
R
Rafael Posted on Feb 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
Samsung UN55HU7200FXZA. When turn on, the right side of the screen I get verticals black and white bars with a black screen (NO VIDEO) on the other half of the screen (left side) and after 2 seconds the screen goes completely black (no video) but I can see the back light on.
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Feb 21, 2017
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994617
Points
237762
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Samsung tv picture goes black to blue and red power button light goes on and off
The device sources and the inputs have not been set to the correct mod.There could be a problem with the TV it's self for it to be turning off like a problem with the power supply for the TV.
50" Samsung Smart 4K TV Doesn't Start Up Right Away & a FEW thin black & white horizontal lines?
Turn the TV off and unplug it from the wall and also unplug everything that is connected to your TV for about 1 minute and plug everything back in again. There could some thing wrong with the power supply or a problem with the t conn board here.
I have 2 closet ceiling lights that were unhooked. Have rewired them incorrectly because when the door opens the lights are suppose to automatically go on and when closed they are to go off. Only one set...
Before you start, turn off the breaker to the wires you are working on.
You should have two 16-2 wires going to your switch, one is the feed, the other will be the line that goes to the light. Put black feed wire onto bottom screw of switch (or top, always be consistent) Put other black from the second wire to the second screw on the switch, this will be your line to the lights with power when switched on. Connect white to white in switch box. The power will come back through the white from the line wire.
Up at the light, make sure you have the 16-2 line wire from the switch, connect the black line from the switch to the two thin black wires from the two bulbs. twist together and put a Marr connector on them. You now have power to the bulbs, the power must come back through the white line 16-2 wire that is in the same sheath from the switch. Connect this white line wire to the two thin bulb wires, twist and Marr them.
Now, you have 2 other 16-2 wires to the octogon light box. My guess is that one is the feed from elsewhere and one is the line to the switch, is that right? Do not connect either of these to the bulbs or else you will bypass the switch.
Below is a diagram but only one bulb, your black line from the switch needs to be marr connected to two blacks, one from each bulb. Remember to connect the bare ground wires together and to the metal box.
Feb 18, 2015 • Home
I have a dsi can i use the internet from my android phone to sync pokemon black, White, black 2, and white 2. Or the dsi shop
Hey there,
Here are a couple guides that show how to create a hotspot on an Android device:
How to turn your smartphone into Wi Fi hotspot
How to Turn Your Android Phone Into WiFi Hotspot
If for some reason your phone doesn't have any options for using it, there's this app you might have some luck with:
FoxFi WiFi Tether Root Android Apps on Google Play
WHITE SCREEN ON SAMSUNG LAPTOP
Prior to the Windows splash screen do you see graphical issues ( black background, white writing, or bios splash screen) if you don't then the problem is with windows and will need to be reinstalled. Samsung ship laptops with a windows cd and is a fairly basic wizard. If you don't know how to do this google is full of guides. If you however see graphical problems right from turning the laptop on then there is likely to be a hardware fault straight from the factory. Contact Samsung and they will repair / replace the laptop through warranty. I have seen several Samsung laptops brand new from the box do this and It turned out to be a hardware issue and was replaced on warranty. Good luck.
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
