Question about Golf
Need wheel bearing for a tour Turk golf cart - Golf
Posted by Frank on
5 Related Answers
weblord
William Nabaza
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
Anonymous
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Posted on Jan 22, 2009
moparownr
Jeff Hammack
  • 667 Answers
SOURCE: Need to see a diagram of how to change rear wheel bearing on my 320 touring 1996
BMW uses CV shafts for the rear drive axle, the wheel bearing there is a pressed in factory sealed bearing and not removable other than using a press to remove it, to press it you will need to remove the lower control arm.
Posted on May 24, 2009
Joe Hogan
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
golfcartman
  • 34 Answers
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Posted on Apr 22, 2010
Where to i get replacement parts for Tour Trek collapsible golf cart
contact golf supply shops
get the manufacturer web page up and check for spares
Aug 21, 2014 | Tour Trek One Click 2.0 Collapsible Push...
Sueaky front wheel
It could be a number of things. First check your brakes for any rocks or excessive dirt. Second, check to make sure you are not in need of new brake pads. Brake pads are equipped with a tab that starts making noise when its time to replace your brakes. Third, have the bearing checked. Once the bearing get excessively worn they will start making a squeaky sound. Also have the shocks checked. the bushing worn out in shocks can also cause the noise. The best bet is to have your local mechanic inspect your front end for any wear. Once he does this, he can compile a list of parts that need replaced. Then you can replace or fix it yourself.
Aug 04, 2009 | 1996 Jeep Cherokee
Hank, The cart man
Jul 17, 2009 | 1995 Volkswagen Golf
Golf Logo
403 people viewed this question
Top Golf Experts
ray gallant
Bill Boyd
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
