Question about Golf
Do you have wheel bearings for tour Trek golf carts model GS501 rear wheel bearings
Dimensions are 3/8 inside diameter 7/8 outside diameter by 3/16 width
Posted by Frank on
1 Related Answer
wekjo
  • 3911 Answers
SOURCE: 2003 Saturn Vue AWD 6
Can you do some things yourself? Why don't you go to this site and find all that instead of asking someone else to do it for you.
www.getsaturnparts.com handles only new oem parts & accessories for all models of the saturn
Posted on Sep 22, 2011
Where to i get replacement parts for Tour Trek collapsible golf cart
contact golf supply shops
get the manufacturer web page up and check for spares
Aug 21, 2014 | Tour Trek One Click 2.0 Collapsible Push...
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
How do I change the drive belet
To remove a 2007 Touring drive belt FIRST remove the rear wheel and the rear swingarm, remove the primary chaincase assembly,remove the old belt from the transmission sprocket.
To install a 2007 touring drive belt FIRST install the new belt on the transmission sprocket, then install the primary chaincase assembly, then install the rear swingarm and the rear wheel and adjust the belt deflection to specifications.
Belt Deflection
Vehicle Orientation Model Inches Millimeters
Motorcycle Upright
With Rear Wheel in Air
or On Jiffy Stand
Without Rider or Luggage
FLHR/C,
FLHT/C/U, 3/8-7/16 9.5-11.1
FLTR
FLHRS,
FLHX1/4-5/16 6.4-7.9
Apr 27, 2014 | 2007 Harley Davidson FLHRC Road King...
What size clutch fits a 2003 gti 1.8t?
comparebanner.jpg Duralast/Clutch Set viewdetailsshelf.gif Part Number: NU31668 Warranty: Limited Lifetime Application: With 6 speed transmission
9 1/2" disc outside diameter
Notes: Spline inside diameter 1 5/16". Spline count 23.
Add More Items to Compare Add More Items to Compare Price: $316.99
STORE PICK UP SPECIAL ORDER SHIP TO HOME AVAILABLEADD TO CART Duralast/Clutch Set viewdetailsshelf.gif Part Number: NU31620FW Warranty: Limited Lifetime Application: With 5 speed transmission
8 7/8" disc outside diameter
Notes: Flywheel Included. Spline inside diameter 7/8". Spline count 28.
May 26, 2012 | Volkswagen GTI Cars & Trucks
Golf Logo
924 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
