Question about Fisher Dishwashers
Hi Sharlene-
I found this youtube video regarding Fisher & Paykel dishwasher repairs.
https://www.youtube.com/results?search_query=fisher+paykel+dishwasher+f24+error+code
I also found this link.https://www.fisherpaykel.com/vault/pdfs/pdf_usecares/599864A_DD60_userguide_CN(EN).pdf
Hope these help.
Posted on Nov 29, 2019
SOURCE: I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
F1 fault means the flood switch on the base of the dishwashers has been activated.You would need to ring someone who repairs dishdraws.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
Posted on Aug 27, 2008
SOURCE: error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Posted on Sep 22, 2008
SOURCE: Fisher & Payke dishwasher top drawer
Try shutting off the power to the dishwasher for a minimum of 5 - 10 seconds then see if that resets the control system.... here is a link for the manual.. they have several trouble shooting sections within it to assist you.. http://www.fisherpaykel.com/global/customer-care/product-manuals.cfm
Hope this helps...
SOURCE: troubleshooting problem with two drawer fisher & payke dishwasher
My dishwasher drawers grind away while showing F1. I have had to turn off the breaker because I cannot get the machines to turn off with the power switches. I turn them off and they just start up again in a few seconds.
Posted on Feb 03, 2009
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker. Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
