SOURCE: Insignia NS-32LCD...Manufactured 2-07
This set should still be under a manufacturers warranty. This set has a board that is very hard to get. Do not let them tell you to wait, or you will wait and not get the set repaired. You need to call and have them repair or have them replace the set before the warranty runs out. If you do you will have a hunk of junk.. Good Luck
SOURCE: Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
SOURCE: How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
SOURCE: Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
