Question about Canon imageRUNNER 2016 All-In-One Laser Printer
How can i fix canon ir 2016j error e 010 - Canon imageRUNNER 2016 All-In-One Laser Printer
Posted by aso latif amin on
5 Related Answers
Anonymous
  • 371 Answers
SOURCE: canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Posted on Apr 15, 2009
Anonymous
  • 82 Answers
SOURCE: when i start canon photocopier ir-2016j , its
Your machine appears to think it's waiting for a file (like an update). Somehow it was put into download mode (only a canon tech would know how to). You need to have a canon technician to either reset the machine or if there is a legitimate problem put it into factory default.
It may be a hard drive error from my experience.
Posted on Nov 29, 2009
mitesh ramboros
  • 78 Answers
SOURCE: no power in iR 2016J
order a new one
Posted on Nov 30, 2009
Anonymous
  • 39 Answers
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
Posted on Dec 18, 2009
edy_bubat
edy copier
  • 306 Answers
SOURCE: I have a Canon IR
it is all about main motor or drum unit.
Posted on May 17, 2011
Canon ir 2016j out of toner change of toner
Hello Asim.
Are you asking what toner replacement cartridge to use?
Your toner should have a sticker with this number on it.
Otherwise Google
canon ir 2016j toner renewal
The above search may also show results for how to replace.
Nov 18, 2017 | Canon Office Equipment & Supplies
I have a canon photocopier ir 2016j. I changed the drum and blade. after installing, I received a system error e007 on the screen. can someone help me?
It is Error in the Fixing Unit Film.
First Go to service mode and clear the Error.
Power the machine and On the machine if problem persists Replace the fixing unit Film
COPIER>FUNCTION>CLEAR>
ERR.
Jun 25, 2016 | Canon Office Equipment & Supplies
I have canon Ir 2016j photocopy machine and it displays system error how do i fix it?
Have you tried unplugging the machine for a few minutes and plugging it back in?
Jun 11, 2015 | Canon IR2016J
How do i fix Error E007 on Canon IR 2016j?
Dear
Replace the fixing film assembly or fixing film.
Thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Pliz help my copy is generating this error system error E007 its a canon IR 2016j
This is the standard Canon error for the fixing film of the fuser assembly not rotating. The film is most likely damaged and will have to have the whole fixing film assembly replaced. It's not a job for the lay person to do. Best left to a technician. Good luck.
Jul 27, 2011 | Canon Office Equipment & Supplies
Ir 2016j system error e007
Your fixing film is damaged.
Replace the Fixing Film - it is not easy to do.
Call a technician to install it.
Or buy a new Fixing part : Fuser - Fixing Film Assembly 120V : FM2-3346
Fuser - Fixing Film Assembly 230V : FM2-3353
http://bopcanon.com/images/view.aspx?productId=106
I hope it helps
Dec 10, 2010 | Canon iR 2016i Black and White Copier
Canon imageRUNNER 2016 All-In-One Laser Printer Logo
63 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
