Question about Sceptre Televison & Video
No sound out of speakers on my sceptre tv. No matter what i hook it to
Posted by Steve Hickman on
shaun taylor
  • Sceptre Master
  • 1,527 Answers
Hi check the speakers with a multimeter they are normally 8ohms, if ok, plug earphones into the tv ,see if you can hear sound if you can the sound prossesor is working you have faulty amp ic or a bad capacitor, thanks
shaun
Posted on Feb 18, 2017
Sceptre 32 does not have sound
Check its speaker first. Check whether the sound is muted. If it is muted, there will be no output heard. If all are correct, check and replace the damaged component/s at its audio output stage circuit, or replace the audio output circuit board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 02, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre tv, no sound no picture
In other-words it is dead. Check its main power regulator board. Replace it.
Jan 09, 2013 | Sceptre 32 X320BVHD 32 LCD TV
I have a sceptre flat screen i bought 2 years ago (40") the sound just quit can hook up external speakers?
Read the owner manual or check all the inputs on the rear to see if it has those connections---it is also possible a surround system routed from a box (cable or sat) might work to bypass this issue.
and do not forget to check in the set menu that the speakers did not somehow get switched to OFF.
Dec 08, 2012 | Sceptre Televison & Video
I have a viz e550vl good pic no sound at all no matter what i do, tried unplug tv hold power button for 10 sec. any help please thanks
have you been already check the speaker does it good?. if ok, tried to hooked up a powered pc speaker at the audio output jack of the tv. turn on, if you can get sound there the cause it would be bad amplifier circuit but if you can not get sound from there you have bad sound processor at the board.
Oct 02, 2012 | Vizio E550VL 55 in. LCD HDTV
I have video but zero audio at all
you must verify first where the problem came from.check in the sound set up menu if set to off, if ok at this time you can use a powered pc speaker to isolate the cause. hooked up the powered pc speaker to the audio output jack of the tv, if you can get sound there the cause will be bad amplifier circuit.if you can not get sound there then the problem is bad sound processor at the board.
Sep 22, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
SCEPTRE X320BV i HAVE PICTURE ON YpbPR BUT NO SOUND/I HAVE SOUND IF IT'S TURNED ON AV
Connect the same input device to some other TV and check. Connect some other device with composite connections and check the TV.
Aug 06, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
No audio on Sceptre TV
I think that you missed to check its speakers. Check it. If they are found OK, the audio output section circuit should be troubleshooted.
Jun 11, 2012 | Sceptre X46BV TV
How to connect external speakers
Hello....I took a close look at your tv and. it doesn't seem to have an output for external speakers BUT...it does have line level outputs so it easily connected to amplified speaker systems or home theatre systems..If you want to expand your system...I would suggest a 5.1 channel surround sound system.....They are priced quite reasonably and will maximize your tv experience.....I hope this was helpful....PEACE...
Feb 08, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
Why does the speakers reverberate sometimes?
Because the speakers are small and get too much power to them. That is the reason why people buy external sound theater systems to overcome most types of sound issues.
Jan 01, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
Receiver Realistic STA 2700: no sound / signal argggh
Sounds like a power supply issue, maybe the transformer when bad, it may need replacing.
Sep 27, 2007 | Audio Players & Recorders
Televison & Video Logo
51 people viewed this question
Top Sceptre Televison & Video Experts
Dave Burton
Level 1 Expert
Ekse
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
