Konica Minolta Bizhub C224 Color Copier / Printer / Scanner Logo
A
Aikona Kelvin Posted on Feb 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kindly assist to reset admin password on bizhub c224
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on May 07, 2017
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910505
Points
11959
Enter service mode
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 287 Answers
  • Posted on Jul 31, 2008
SOURCE: Canon ir C3100 Admin Password
Hello skunkel,
Yes, I believe I can help you. Hopefully these previous admin person did not go nuts with the security thing. But I can help you either way. The least painful method. Approach the copier and view the operator control panel as we are going to go into service mode and delete the admin password. I am about to describe a "fluid 3 step keystroke " function which will put you into service mode. Before we start , locate the "ADDITIONAL FUNCTIONS" button located between the LCD screen and the 9 key pad. Now, press additional functions, then the numbers 2 and 8 simultaneously, then back to additional functions in a smooth three step flow. The screen will change as you have entered service mode. Depending on the configuration of the device you will have several tabs in your display and copier will be at the top. Press copier. A new display appears with several tabs across the top. Press the function tab. New display again, and now press "clear". New display again. Look for "PWD-CLR". Once found, press it. It will be highlited,and then press the "OK" button in the lower right corner. The ok button will indicate you have touched it by beeping or highlighting or both (depends on the model). Then turn the main power off (the actual switch not the button on the op panel. If you are in doubt unplug the machine. After a few seconds re-energize the copier. If the previous administrator merely used a password then it is now deleted and you are home free. If not, then you will need to enter service mode again.......copier........function.......clear..... and then find MMI . Clearing this field will delete ALL customer inputs(IP address, favorites etc). If it is necessary press MMI and then ok. Usually you wont have to do this. But if you do you can have the fun of re-entering all your old settings as it will go back to factory settings.
Anonymous
  • Posted on Apr 02, 2009
SOURCE: Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Anonymous
  • 68 Answers
  • Posted on Oct 05, 2009
SOURCE: admin password
Try to type "admin" and press # key
Anonymous
  • 44 Answers
  • Posted on Nov 29, 2009
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
MSM
  • 165 Answers
  • Posted on Nov 27, 2010
SOURCE: i have forgotten the
try admin or administrator no password
How to reset admin password on bizhub c224e
https://www.copytechnet.com/forums/konica-minolta/100443-how-reset-admin-password-bizhub-c224.html
Quoting from link:
" Re: How to reset admin password on bizhub C224
Once in service mode do a STOP, 0, C
You should then have an option to reset admin password
The manual has these steps to reset."
2helpful
How to reset a password of bizhub 600-750
Which password the admin or the individual passwords Default admin 12345678 or 00000000
Go to:
Admin setting- Security setting -admin password
1helpful
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
C9401 bizhub c224
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
1helpful
3answers
I brought a bizhub 420, how do i reset password
I had an older Minolta a couple of years ago. I'll try adapting what worked for it to this machine. Hopefully this will work.
Press the "utility" button. Then hit "admin settings". Enter a password of 12345678. Then hit "user authentication" and put in "off". Hit panel reset from the main menu.
Again, I'm not entirely sure this will work for the 420 but its worth a shot. Good luck!
9helpful
3answers
How can I rest the admin password on Bizhub c250
still having trouble..if default password didnt work for you then try reseting it to default password by:
1) Utility/Counter
2) Details
3) press STOP zero zero + STOP zero one
and now your in Tech Mode
4) same page press STOP + Zero + C
5) modify admin password and retype and then exit
6) do not DO NOT touch any other options unless you know what your doing..you can lock the machine and would be able to work..rate if this helped you out
110helpful
13answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
