Kitchen Appliances - Others Logo
Mary Sessum Kimmitt Posted on Feb 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Foodsaver V3835 seals but will not sufficiently vacuum.
Lawrence Oravetz
Level 3:
  • FoodSaver Master 10,558 Answers
  • Posted on Feb 18, 2017
Lawrence Oravetz
FoodSaver Master
Level 3:
Answers
10558
Questions
Helped
2695747
Points
29284
Go on the Foodsaver website to get replacement foam rubber seals that contact the bag during the vacuum process.
3answers
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
2answers
Foodsaver repair
Sorry to laugh, but that is too funny!
These retractable cords are very difficult to get back in order. You would be better off just closing up the sealer and allow the cord to remain extended. You could spend hours rewinding the cord and setting the tension spring when it pops open and makes you a crazy person.
FOODSAVER V3880 DOESNT GET GOOD VACUUM IN BAG
Sounds like the foam seals are leaking. Go to their website to get replacement parts.
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
Tray full light won't go off & the tray is empty
Have the same problem. I'm looking for a solution too. The tray is dry and clean as a whistle. I cleaned all elect. connections and even dryed it all around with a hair dryer.
1helpful
2answers
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
17helpful
3answers
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
My Food Saver V3835 will not seal canisters. It seals bags AOK but there appears to be no vacuum generated through the extension tube. We have tried several different canisters and covers. I have also...
The negative pressure is very slight and almost not detectable when using canisters for food storage. Once the system is activated, and allowed to run until timed out, the canister should have pulled all the oxygen from the canister. Foodsaver only canisters are designed for the V3835 for vacuum sealing.
How to Vacuum Package Using Your FoodSaver® Vacuum
Packaging Canister
NOTE: FoodSaver® Vacuum Packaging Canisters can only be used with
a FoodSaver® appliance that has an Accessory Port. Please check your
QuickStart Guide to see if your appliance has one.
1. Place your FoodSaver® appliance on a fl at, dry surface and plug the power
cord into a standard electrical outlet.
2. Place the item(s) to be vacuum packaged inside the canister. Leave at least
one inch (1”) between the contents and the rim of the canister.
3. Wipe rim to ensure it is clean and dry.
4. Place the lid on top of the canister. If the canister has latches, put them
in an upright position so that the lid fi ts on the base. Push the latches
downward until they snap into place.
5. Insert one end of the Accessory Hose into the Accessory Port on your
FoodSaver® appliance.
6. Insert the other end of the Accessory Hose into the hole on the top of the
canister lid. Twist the gray tip of hose while inserting to ensure a tight fi t.
7. Follow the steps for vacuum packaging as outlined in your QuickStart
Guide.
8. Remove the Accessory Hose from the Accessory Port on the appliance
before vacuum packaging in FoodSaver® Bags.
Allow hot foods to cool to room temperature before vacuum packaging. Otherwise, the
contents may bubble up out of the canister.
How to Open the FoodSaver® Vacuum Packaging Canister
To open, press and hold down the gray rubber button in the center of the lid
until you no longer hear air escaping. This will release the vacuum and allow you
to easily remove the lid.
Top FoodSaver Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
