Question about Toshiba 55H70 55" Rear Projection Television
Toshiba Cinema Series
When I try to turn my TV on via the remote or actual TV power button, all I get is a flashing red light. The problem came about rather suddenly as one day it worked and the next day it didn't. My kids had been pushing the power button on and off so maybe that lead to part of the problem. Thanks in advance.
Posted by casinorg on
  • koryd Dec 06, 2007
    Same problem, wondering if a solution was ever presented...? Same problem but with a TP55E80. Please respond ASAP or it goes to the dump! Thanks!
  • Anonymous Mar 21, 2014
    my tv has sound no pic red light flashes on front worked fine 2hrs earlier
Anonymous
    Sergeant:
    Champion:
  • 375 Answers
Possible regulator ic. in the power supply.
Posted on Dec 16, 2007
Panasonic plazma tv th-42pd50u. Red light automatically turns on when connected to power and stays on. No clicks, No blinks and No picture. Is this a faulty power supply board?
possible reasons, its in standby, hold in the proper ON button on the tv for up to 20 seconds gently. or try disconnect power(pull plug out) wait 10 seconds, plug back in and turn on using the actual button(holding for up to 20 seconds) NOT THE REMOTE if that does not work, make sure your INPUT is CORRECTLY selected eg you are viewing HDMI1 and NOT HDMI2 for example. there may be different procedures for flashing lights
Dec 12, 2017 | Panasonic Televison & Video
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
My tv has a red button on the front that flashes and no picture comes on when we try to turn it on with the remote
The Toshiba sets were well known for bad capacitors in the power supply. I recommend getting it assessed.
Mar 19, 2012 | Toshiba 32AX60 32" TV
TV doesn't turn on
I have a Mintek DTV265 which is almost the same TV the red light don't blink it stays on as long as the Power button is on. Try turning on the TV by pressing any of the buttons on the side of the TV Channel up or down, Volume up or down , or source. If it comes on then your TV is alright. I had one of them jumbo universal remote controls and it actually had a code that worked on my TV.
Mar 02, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Feb 01, 2009 | Home Security
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
512 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
