Question about Precor Exercise & Fitness
Precor 956i error 44
Quick start and incline and speed does'nt work
Posted by Kenny Lee on
5 Related Answers
tunde007
Tunde Autos
  • 2382 Answers
SOURCE: My 956i just started causing
Hi, the belt is erratic this indicates problem with DC board or the motor. Manually push the belt in the direction in which it normally moves. If you have difficulty turning the belt, there may be an issue with the belt/deck friction. If the belt turns freely, there may be an issue with the DC board output.
Use a multimeter to test the black and red lead wires that connect the motor to the power supply. An external power cord connects the motor the power supply.
Most probably its a motor issue.Its got weak,because in most of the cases its seen.But in some cases the board is checked faulty.-------- Get the motor as well as board checked to confirm the fault.
This will help
Posted on Apr 22, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Precor C 962 Display works, but when start key press nothing happens!
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Remember :The controller for console or display have circuit for magnetic swithc.
Posted on Nov 21, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: My precor 956i sets the reset button off after 20 mins of use. It is on its own 20 amp circit.Sometimes it shuts off sooner
You have mixed problems: mechanical-electical-electronics
I am giving a combo for solutions Watch the videos-tips for mechanical adjustments firts:
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
http://www.youtube.com/watch?v=dxpOOPetVLo
If the problem persist, go to the 2nd phase:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA
After this adjustments, if the problem persist you will be Strong conclusion: 1) Transformer Faulty, 2) Speed SENSOR 3) Main Motor 4) PController Motor Board, Since PCB controls 90-95% functions of the treadmills. sincerely.
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Hello, I need a circuit board for Precor 956i, international model (230v).
Dear Sir:
You can go www.fitnessrepairparts.com + www.treadmilldoctor.com +www.treadmillpartszone.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Mar 10, 2012
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: quick start keys (quick start, speed, incline) do not work on the handlebar
1) Run the software callibration for diagnose and troubleshooting and fix it. Read your instruction manual, if you do not have go www.fitness.manualsonline.com or www. iconservice.com
see the block diagram for better understanding
God bless you
Posted on Jun 21, 2012
Treadmill belt runs too fast and will not power off with control panel
Step 1:
test the speed sensor,m for open or faulty, clean it, and tight the connector. see the diagram attached.
However follow the steps for RUN the.s calibration for fix it.
God bless you
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 07, 2013 | Exercise & Fitness
My TM won't work in the incline mode. We recently reset it up and started it before we had it in the proper alignment (walking surface to motor) and engaged the incline function. There was a bolt
Please RUN the software caibration for diagnose, troubleshooitng, and fix it Maybe you have speed sensor faulty or bad adjustment, clean it and tight wires connector.
God bless you
Jul 26, 2012 | Proform Quick Burn Pro Treadmill with 12...
Quick start keys (quick start, speed, incline) do not work on the handlebar
God bless you
Jun 20, 2012 | Life Fitness 95Ti Treadmill 95 Ti
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Repco Sports Treadmill
Repco RP300TM wont start E1 error message
Jul 15, 2009 | Exercise & Fitness
Exercise & Fitness Logo
121 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
