Afraid of breaking the lcd screen so I want to know the best way to take down the panel
SOURCE: samsung tv settings
Freeview Built-in Tuner
Picture Mode: Standard
Contrast: 85
Brightness: 53
Sharpness: 25
Colour: 45
Tint: 50/50 (Greyed Out)
Colour Tone: Cool1
Detailed Settings:
Black Adjust: High
Dynamic Contrast: Off
Gamma: 0
Edge Enhancement: On
White Balance:
R-Offset: 17
G-Offset: 15
B-Offset: 11
R-Gain: 7
G-Gain: 14
B-Gain: 30
Backlight: 10
Digital NR (Noise Reduction): Auto
Active Colour: Off (Greyed Out)
DNIe: On
Movie Plus: On
Sound Mode: Music
SRS TX XT: On
Game Mode: Off
Energy Saving: Off
SOURCE: I need replacement screen for Samsung Digimax D103
You may try to contact 1-800-SAMSUNG and have your camera sent for service.
SOURCE: intermittently, picture seems to break up into
replace the cable from the source. if the images tiles up it could be the cable and I suggest doing this first: replace the cables, they are the lowest cost to check, and in some cases the cable company will replace the length of cable from the TV to the wall for free (or part of your monthly payment). You could always make your own the stuff for that can be found on sites like www.compressionconnector.com of course you could always buy the cable if needed. I am assuming this is occuring during normal TV viewing. if it occurs while watching DVDs or from other sources you likely have a problem with your TV and may need to get it repaired.
SOURCE: New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
