Televison & Video Logo
M
Maria Gosling Posted on Feb 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHat does the icon of a circle ,with a diagonal line across from top left to bottom right mean?
Small icon at top right corner of bush android tablet
Marvin
Level 3:
Top Expert:
  • Televison & ... Master 85,242 Answers
  • Posted on Feb 16, 2017
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037110
Points
266281
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
How to remove bookmarks
Open Safari, click on the little book icon in the bottom of the screen. It will open your bookmarks, hit Edit in the bottom right corner. It will bring up red circles with lines in them on the left of the bookmarks. Tap on that, it will delete those bookmarks.
1helpful
3answers
How do you delete messages from iphone 5c
Swipe left on the message and press delete
1helpful
How do I change language back to English
Assuming Android system.
Enter " Settings " ( gear ? icon generally located in bottom right corner, newer Android versions )
Scroll down - Left side
select - Capital Letter " A " ( Language )
then, on Right side -
select 1st / first item
next - scroll down list and select your preferred Language.
Location of the usb pins on the mainboard
http://www.matsonic.com/Computer-Desktop-Support/Models/ms9307c%2Bseries.php
Go to the small list on the left side, under the bold black subheading - Matsonic Motherboard Manuals (PDF)
Left-click on - MS9307C
When the small window comes up on the right, make SURE there is a Green dot, in the small circle to the left of - Save File.
IF not left-click in the small empty circle to the left of Save File.
Now go below, and click on OK.
A small window will come up on the left. Allow the file to fully download. Then DOUBLE-click right on the file name.
Go to the far left side, and click on Extract all files.
Then click on Next, Next, and Finish, at the bottom of the next three small windows.
In the last small window DOUBLE-click right on the file name, next to the red Adobe PDF icon.
There is the motherboard manual.
Go to Page 14 of the Adobe Reader page number. (Top header)
Actual manual page number is 10.
Motherboard installed in computer case, USB1 header is at the bottom right corner. It lays Parallel to the bottom of the motherboard.
5 pins across the Top row, 4 pins across the Bottom row.
USB2 header is right above the top white PCI slot. (PCI 1 slot)
5 pins across the Top row, 4 pins across the bottom row.
Pinout for the USB headers is on Page 22 of the Adobe Reader page number. Page 18 for the actual manual page.
Regards,
joecoolvette
http://pinouts.ru/Slots/USB_pinout.shtml
K9n6pgm2-v pin out
MSI Support > K9N6PGM2-V motherboard > Main Support page,
http://www.msi.com/product/mb/K9N6PGM2-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc)
In the drop down list click on - Manual
Now click on the blue -> M7309V1.2.zip
Click on the country name nearest yours.
A small window will come up on the right -
Opening M7309v1.2.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
If not left-click once in the small empty circle, to the left of Save File
Now go below in the window, and click on OK.
A small window will come up on the left. Allow the file to download all the way.
Now DOUBLE-click right on the file name.
In the next small window go to the left side, and click on -
Extract all files
At the bottom of the next three small windows, left-click on
Next, Next, and Finish.
In the last small window go to the file name next to the red Adobe PDF icon, and DOUBLE-click on it.
7309v1.2(G52-73091X3)
There is your motherboard manual in PDF file form.
( Plus + icon increases the view size when you click on it.
Minus - icon decreases the view size.
When I refer to a page number it will be for the PDF reader, and not the actual manual's page )
Go to Page 8.
Motherboard Layout
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
JFP1 is the Front Panel header.
JFP2 is an additional header. To be discussed after JFP1.
JFP1 is on the Right/Bottom corner. It is placed Vertically.
(Parallel to the right bottom edge of the motherboard)
Above it's left corner is JUSB2. (Front Panel USB header 2)
Above JUSB2 is the SATA2 connector. To the left of the SATA2 connector is the SATA1 connector.
To the left of the SATA1 connector is the CMOS battery.
The contact pins are arranged in two columns.
4 pins on the Left side, 5 pins on the Right side.
Go to Page 14. JFP1 pinout, and JFP2 pinout, is at the Bottom of the page.
JFP1:
Starting on the Bottom going towards the Top, Right side;
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going towards the Top, Left side'
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. (Probably 5 Volts positive, and used by the factory only)
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
IF the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
JFP2:
Below JFP1 is a header that is placed Horizontally. It is parallel to the Bottom edge of the motherboard. This header with 13 pins in it, is the JLPC1 header.
(Starting on left side at the Top row; 4 pins, no pin, 2 pins.
Starting on the left side at the Bottom row; 7 pins)
To the left of the JLPC1 header is the JFP2 header.
4 pins across the Top row, 3 pins across the Bottom row.
The top 4 pins across the top are for an internal speaker. Used to hear BIOS Beep Codes.
Starting on the Left side coming towards the Right, top row;
No indication of polarity.
Believe pin 2 is for the Positive wire, and pin 8 is for the Negative wire.
Starting on the Left side coming towards the Right, Bottom row:
Pins 1, 3, and 5.
These pins are ONLY used for a Power On LED light, that has 3 wires.
Used for a dual color Power On LED.
(One example; Green Turbo, Yellow normal)
The rest of the pinouts are listed in the manual.
Have additional questions? Post in a Comment.
I also downloaded the manual.
Regards,
joecoolvette
Our motorolaom is set to chinesewe cannot unerstand the options needed to change it to enish?
mine was like this.
Switch on
At top right hand corner there is a + sign. The chinese next to it means apps. Press
This should bring up the page with symbols. Rond symbol with blue ring inside is settings possibly 3 line 6th symbol along. press
4th line up from bottom has a "a" press. This is language. should give you the english option. Good luck
Puzzle 100
heres a hint
1. Most of the squares you make will be tilted 45 degrees
to the side, and their sizes will vary as well.
Start by looking for pins you can connect to create squares
at a diagonal.
2. You want more specifics? All right, here's the location
of one of the squares. Connect the four pins in the top-left
corner to form a tiny square. Just so you know, this is the
only square on the board that isn't tilted.
3. The largest square contains the pin that's third from
the top on the left column and the bottom pin from the far-right
column. You also need to form a small diagonal block using the
two pins lined up diagonally on the bottom-left portion of the
board. There are two more small squares just like this one on the board.
J5
1helpful
Screen lines on MacBook.
Sounds like dropped pixels.  My first guess is the computer has been dropped on its corner, with the pixel dropout radiating diagonally from the corner.
My saint bernard sat on my g3 lombard, and I have vertical pixel dropout because of it, from the top of the screen to the bottom.
And no, it is not normal for a macbook to have lines across the screen.
Linda h.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
