Watches Logo
C
Clarence Walker Jr Posted on Feb 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Lorus Tri-Lum solar watch seams to charge up but no second hand movement.
Marvin
Level 3:
Top Expert:
  • Lorus Master 85,242 Answers
  • Posted on Feb 16, 2017
Marvin
Lorus Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053759
Points
266281
I would suspect the battery is defective.
Lorus V422 Mickey Mouse Watch. Why will my watch not keep time after installing a brand new battery?
Question edited for clarity and correct maker spelling.
Question moved to Lorus Category.
Wrong battery with wrong voltage and battery chemistry.
Or dirty contacts to the battery.
https://www.manua.ls/lorus/v422/manual?p=3
https://www.google.com/search?q=lorus+V422+battery
tip
How to submit questions about watches
To submit correct question about any watch here on FixYa you have to give as much details of particular watch as possible. There are hundreds of people asking for help, but it makes no sense if the question, for example, is: How can I adjust my Citizen stainless steel watch? Citizen, as any other watch manufacturer produces thousands of watch models and every year few hundreds of new models are added. This makes impossible to recognize any watch by the brand name given only.
So, to make sure that you will receive proper help with your watch, please always submit:
1. Brand name;
2. Model name;
3.Type of display ( Analog or digital or both);
4.Type of movement (Mechanical, quartz, kinetic, solar e.t.c.);
5.Number of the watch (Usually written on watch's case back);
6.All the writings you can find on watch's case back.
If you are not sure what type of movement your watch has, here is a tip how to find it out: Observe watch's seconds hand. If it is moving in jumping action second after second - your watch has a quartz movement which is battery driven. If the seconds hand is moving in sweeping action - most likely your watch has mechanical movement which is driven by spring.
The more information you will submit, the better.
on Jan 08, 2010 • Watches
I left my timex solar watch in my watch case too long - and it stopped working. How do I repower the watch. (I have had it out in sunlight for a couple of days).
I am thinking you need a new battery. It appears to be a battery operated watch that runs on solar power IF there is light.
How long will a Timex Solar watch last?
The solar movement functionality creates an environmentally-friendly and maintenance free timepiece that can be charged through indoor fluorescent light or outdoor sunlight. Once fully charged, the battery life can reach two months. If worn daily, there is very little chance the watch will stop.
Solar Powered Watches ' Timex Blog
Lorus mens watch does not work despite fitting a new battery
its possible that the coil on the movement has been damaged.
i would adbise to take to a local store to get a price to replace the movement.
2helpful
2answers
My seiko is keeping good time but the second hand jumps two seconds then hesitates for what seems to be a second then skips two seconds again
There are three solutions for this problem, contingent upon the model:
With both instances, this is a power saving / low charge / low battery feature of the timepiece.
1) Is your Seiko watch a Kinetic / Solar model? If so, your watch contains a capacitor. The capacitor may be bad, OR if you have not been wearing it on as regular a basis, wind the watch (Kinetic) vigorously for 5 minutes, and if the second hand returns to normal function, the capacitor is most likely fine. If is is a Solar model, expose it to sunlight for 4-6 hours or incandescent light for 24 hours and see if this resolves the problem.
2) Else: if this is a standard battery operated watch, take your watch to an authorized Seiko repair center, or Certified Master Horologist. Make sure that the Seiko Repair Center is using Seiko batteries, else make sure they are installing Energizer only - these two batteries will not leak in your movement. Avoid other batteries at all cost, many of them will leak and ruin your movement.
3). If these solutions do not work, and you have not had your watch serviced in the last 3 to 5 years, you need to service the movement. See the aforementioned parties to begin the process.
4) If your watch is water resistant, and/or you plan on wearing it in the water, make sure to have your watch water tested by the appropriate aforementioned professional to ensure it will withstand proper dynamic and static pressure at the appropriate depths.
Feb 04, 2011 • Watches
2answers
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
2helpful
My MTG900 says, "Charge" on the screen...I got it last Christmas, does this mean I need a new battery?
CHARGE means you have to charge the watch. It depends on what type of movement you have. If it's solar powered, you need to leave your watch under the light to charge it. If it is battery powered - you haqve to buy the new battery and fit it. Rate me,plz.
2answers
The ladies disney citzen eco-drive requires a charge
Follow this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Interactive settings are helpful as well.
Rate me, please.
Watch not charging?
Hi there.
There are two types, A kinetic rechargable one, and a solar one.
Just check it is the solar one!
Try wearing it for a day and see if there is any change at all.
If it does nothing, there may be a fault with the rechargable battery. If so , it is cost effective to have this repaired.
Top Lorus Watches Experts
deton8 von Splosion
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Lorus Watch Expert? Answer questions, earn points and help others
