Kitchen Appliances - Others Logo
K
Kathy Adams Posted on Feb 15, 2017
I have a Toastmaster waffle iron 269A and need the right leg/handle. Do you have one?
5 Related Answers
Jerseybob
Robert Weir
  • 18 Answers
  • Posted on Apr 02, 2008
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Anonymous
  • 47 Answers
  • Posted on Jan 04, 2009
SOURCE: Toastmaster waffle maker - have no manual
http://dl.owneriq.net/4/4d7525b4-d3f8-43f8-b5a9-03673112a1e9.pdf
Here it is, you may have to join but it is free!
Anonymous
  • 6 Answers
  • Posted on Mar 16, 2009
SOURCE: The handle on our 13124 Bella Cucina waffle iron
I had the same problem, so I contacted their customer service at (866) 832-4843.
I was informed they don't replace that part anymore.
Sorry!
Anonymous
  • Posted on May 02, 2009
SOURCE: toastmaster 287 thermostat
I had the same problem a few weeks ago where the Ready light came on and stayed on. After opening it up I realized the little disc is a thermostat. After some Internet searches I found out who the manufacturer was and emailed a sales guy there. They didn't sell retail, but he recommended www.selcoproducts.com. It took some more research to figure out which kind I needed because there are a lot.
Choose there Thermal Products link, then Disc Thermostats, 1/2" Disc - Automatic Reset. You'll want the Open On Rise type. There are all kinds of different temperatures and I had a real hard time finding what temperature to buy. I found a patent that said 166 Celcius (about 300 F) so I got that type from the 1/2" Disc - OA Series link. It isn't as high a temperature as the old one so I run it for 2 cycles of the Ready light and it worked perfect. You may want to try their higher temperature ones under the 1/2 Disc CR/OR Series - High Temperature - Polyester, or Ceramic if you want to try higher than 365 F. Whichever you get make sure under Mounting it says Rotating Bracket. It will show you individual pictures of each so you'll see what you want.
They have a minimum order of $50, though. So you'll want to buy a few. I had to buy 5, but with the High Temperature ones you probably can get away with 4 since they are slightly more expensive.
Anonymous
  • 4 Answers
  • Posted on Jan 03, 2010
SOURCE: Repalcement plates for Model 270A Toastmaster Waffle Iron?
Actually I have a Toastmaster 270A waffle iron. It is much better quality than the later toastmaster models, and it is basically identical to the Black & Decker model G48TD, which is still sold. You could get plates from Black & Decker. The entire iron sells for $50.
2answers
What Is an Easy Way to Clean a Waffle Iron?
Here's a Toastmaster manual which explains proper cleaning.
Find a leg for toastmaster waffle maker model 270 or 290
http://www.searspartsdirect.com/partsdirect/part-model/Toastmaster-Parts/Waffle-maker-Parts/Model-270/1097/0213700/00039364/00001?blt=06&prst=&shdMod=
How to use the waffler by toastmaster model# 2810R026
Directions
  1. Preheat waffle iron. Beat eggs in large bowl with hand beater until fluffy. Beat in flour, milk, vegetable oil, sugar, baking powder, salt and vanilla, just until smooth.
  2. Spray preheated waffle iron with non-stick cooking spray. Pour mix onto hot waffle iron. Waffle is usually done when it stops steaming. Cook until golden brown.
2answers
Need the manual and recipe
Here's a manual for my W252, which is similar to your model.
1helpful
2answers
2answers
Toastmaster manuals
Here's a recipe page from one of my Toastmaster manuals.
I have a model 269C toastmaster waffle Baker.. and need to replace the right handle which has a broke leg and is unstable ... other wise it's new... never been used
You can often find good replacement parts for waffle irons on eBay using your make and model # in the search box. Or buy another cheap used one in the same model and rob the parts from it.
Can Toastmaster 218 work on 220V?
Any electronics bought in the US will work on 110V. You will need a voltage converter if you want to use your Waffle Maker in Italy. I have one, it is very easy to use!
283 S Waffle Iron.
You can try this site: http://kitchen.manualsonline.com/manuals/mfg/toastmaster/287.html
Its not the exact model but sometimes they are close. Hope this helps.
2helpful
2answers
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Top Toastmaster Kitchen Appliances - Others Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
