Computers & Internet Logo
Question about Time Computers & Internet
I have amano t9 time attendance machine forgot my password. need heop to reset.
Amano t9 0432 finger print time attendance device and forgot my password..any one can help me to reset password.thanks
Posted by farooq on
Rick Hickerson
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 119 Answers
Contact Amano t9 time and ask them!
Posted on Sep 11, 2017
5 Related Answers
Anonymous
  • 198 Answers
SOURCE: Finger Print Scanner
Hi again. Give me your email adress please, for me to send you the required upgrades. Read my other post in the other section you've wrotten and you will have the instructions on how to do everything there. Thanks.
Posted on Jan 23, 2007
Anonymous
SOURCE: Dp301p+ psadmin password was forgoten
Reset The Printserver from Backside & Gave PAssword again
Posted on Jul 03, 2008
Anonymous
SOURCE: can help?
Switch off your mobile and press *3and calle botton at a time your mobile will formate but make sure that yours battary should be full charged
Posted on Aug 10, 2008
Anonymous
  • 1959 Answers
SOURCE: need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Posted on Apr 16, 2009
Anonymous
SOURCE: Reset admin password for web-interface
If you're 'ok' with resetting all the network info such as Ip address, Etc - not to mention the scanner locations, fax speed dials etc. then you can email me. I will give you the instructions to reset "NCS" which will set all network settings to default, but I haven't got the time to walk you through all of the reconfiguration settings - - you're on your own there.
[email protected]
I don't post service mode adjusmtents here
Posted on Apr 18, 2009
2answers
I need help on how to reset my password I forgot the password and can't access my machine ?
If you have win 7 or lower there are ways of getting into the control panel and resetting the password so you can boot the computer. Do a google search for your specific OS and you will be rewarded.
Why do minutes do not print?
The minutes do not print for one of these reasons.
1. It is not programmed to print the minutes (it may be programmed for a message, date, year, or other characters.)
2. The Ink ribbon is out of ink. Amano PIX Series Ink Ribbon CE 315151
3. The printer is either out of alignment or needs service
4. The Battery is low/dead.
www.gatewayitme.com
I forgot password of ls-838 lonestar biometric
The password is present to prevent the usage of it by a thief after it has been stolen.
AMANO MJR 8000 print problem
it needs to be serviced. try www.gatewaytime.com
3helpful
Hp pavilion dv5 blocked
You can reset your HP windows password directly.
The experience that I forgot windows password happenedto me a few weeks ago. My friend Acheson who is an IT engineer recommended meto take use of Windows Password Reset,which is very smart windows password reset tool and just take me a short time to reset a newly password.
2helpful
2answers
How do i get into my android when i forgot the finger pattern cod
Keep trying the finger code until it tells you have done it too many times. After that it will ask for your Gmail address and password and then you will be able to get into your phone.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
We have a biometrics gadget in the office to monitor time in and out. My finger prints are so shallow that the machine always fails to recognize my finger print. What do i need to do.
to sign my daily (though a fingerprint machine )attendance I face continuos annoying problem which the fingerprint machine can't identify me in spite of I changed the fingerprint from finger to another but everyday i face this disgusting problem .\r\nwhat can i do?
2helpful
3answers
Password was forgot psadmin of 301p
viaujocposted a brilliant solution which worked for my DP-300U: see http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
To paraphrase,
First try logging in with the following
username: psadmin
password: SYSXXXX
(where XXXX is the last four digits of the mac address)
If it works, you can proceed to reset the password.
Alternatively, you may be able to extract the original password from a configuration backup, if you have one. For details, see http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten
Top Time Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Thomas Perkins
Thomas Perkins
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
