You mean after you change the setting and then it doesn't
pull any more.?
-If so the foot tension need to be re adjust. (More tight or loose)
-Here try this:
1. If thick fabric then need more tension.
2. If thin fabric then need less tension.
*After try the above if still not work then:
4. Lift the foot up and spin the machine by hands and observe the dog feed. It should swing pass above the surface about 1/32 (+/-)
-If it swing but stay below the surface then the
internal part that spin the dog feet is worn out.
Good luck
Mai
