Question about HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 scanner error 5 , how can I rectify
Posted by Kannan Balaraman on
2 Related Answers
Anonymous
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
Mohan Fatehpuria
  • 32 Answers
SOURCE: hp laserjet 3055 scanner error
Fat bed lid should be clean and closed, Scanner assy should move and scanner bulb should glow for a while, during the booting process.
The Flexible Flat Cable (pitch 1 mm x 30 Pin) should not be damaged (replace if damaged) and well pushed inside its jack in the formatter. (Open the right side cover and check).
The flat bed scanner's glass frame & Door base should mate perfectly with ease. If opened earlier, the ADF wire harness which passes on the inside along the rear right corner, can prevent PERFECT mating (if in palce the mating would not need any pressure and would fit in place easily), A gap of less tahn 1 mm can be the culprit.
If problem still persists open the scanner flat bed cover, clean the guide rod, check the laser assy movement, clean the black stripe above the resting place of the laser unit, laser unit mirrors ( 4 nos - with lint free fabric and Iso=Propyal Alcohol) re-assemble the flat bed cover with laser assy mid way on its path (to check movement when you boot). Ensure perfect mating as above stated.
If problem persists I fear you may have to replace the scanner assy or the formatter. Before you decide to replace formatter try "Permanent Storage Init" process posted by me for PC scanner "No connection" error.
GOOD LUCK
Posted on Jan 29, 2011
How to solve scanner error 5 in HP LASERJET 3055?
The stepper motor controlling the scan arm is defective. Replace motor or entire unit.
Aug 07, 2014 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
Scanner error 6
most likely dust on the scanner optics causing scanner to be unable to go to home position. Solution would be to disassemble scanner assy and clean optics or replace scanner assembly.Note HP service manual says to replace scanner assy.
Dec 16, 2008 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
204 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
