Question about American Standard Home
I have a shower head drip and replaced the cartridge in a single handle American Standard shower valve. After reassembling I still have the drip, looks like even more constant.
Posted by Johnny Martinez on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: price pfister single handle shower faucet
home depot has all the parts for price fister
Posted on Feb 04, 2009
dragonsthatk
Albert Getty
  • 547 Answers
SOURCE: Shower handle will not shut off the valve...constant drip
little cover cap on center handle screw inside
Posted on Feb 21, 2009
Anonymous
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
odiebugs
odiebugs
  • 949 Answers
SOURCE: how to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Posted on Feb 10, 2010
Testimonial: "Thanks for the info! It turns out that our faucet was so old it had black plastic piece that had to be popped out and re-positioned!"
Mike
  • 4369 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
Water will not flow through on american standard with pressure balance. Some hot water came out with low pressure then stopped and now nothing will flow.
I just spent a week wrestling with a similar problem, and I'm posting in an attempt to save someone else an ulcer. Using a Colony single-handle valve, the temperature got so we couldn't control it. Either all hot or all cold. I called A.S. and they sent a new pressure balancing cartridge and new valve cartridge. Replaced both and then there was no water at all coming out of the shower head. Tried every possible combination of old and new parts, flushed pipes, etc. Finally took the shower head off and found it completely clogged with debris. It was a mix of sediment and the white grease that was in the new cartridges, which must have been displaced when I started messing with it. And it clogged it all at once (no flow problems before all of this). Works fine now!
Jan 02, 2011 | American Standard One Handle Shower Only...
I have an American Standard shower that drips out the shower head. When other faucets are used in the bathroom the water pours. I replaced the cartridge put it still drips.What could be the problem?
Hi kwbaker!
Assuming the cartridge is new and the water drips at both hot and cold settings, I would check your shower head. It is not uncommon for debris to collect in the screening there and clog the spray nozzle.
To check the shower head you'll need to remove it from its piping. Use two tools--I normally use an adjustable wrench and a strap wrench--to hold the wall pipe and simultaneaously turn the shower head counter-clockwise. The cresecent wrench grabs the hex-head of the shower head, while the strap wrench holds the chromed piping without scratching it.
Be sure you don't lose the rubber washer inside the pipe-to-shower head connection!
Once the head is removed, look inside it at the pipe side. You should be able to see into the mechanicals of the shower head--very often I'll see bits of rust or scale. Oftentimes its enough to rinse the pipe side of the head under a sink; in extreme situations it can be easier to replace the entire shower head.
To replace the shower head, use two tools in the same manner in which the head was removed: crescent wrench to turn the shower head, strap wrench to hold supply piping. This time, however, turn the shower head clockwise until it tightens snug.
Hope this helps!
--Joe
Nov 12, 2010 | American Standard One Handle Shower Only...
I have an american standard kitchen faucet, when the handle is half open I get a leak, at home depot where I bought it two years ago, they told me I need to take it apart to see which kit will repair...
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge.
Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
Oct 08, 2010 | American Standard Kitchen Faucet 6310 020...
How to fix a dripping faucet?American Standard single lever handle.
Hello. These faucets use a replaceable cartridge valve and when they drip they're ready for replacement. Remove the handle by loosening a small screw ,usually with an allen wrench, and maybe another nut under it.The cartridge should pull out but mat be stubborn. Take the valve with you when you go shopping there are many variations.
builderdale
Jan 22, 2010 | American Standard - Lavatory Faucet -...
The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Oct 11, 2009 | Delta & Single Handle Shower Faucet
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Sep 25, 2009 | Delta & Single Handle Shower Faucet
SHOWER HEAD DRIP
the problem is in the shower fitting the part with the handle ,depends on who made it but you replace washers or a cartridge some times easy some times not
Aug 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single knob for shower and tub wont stop running
You may have debris caught in the cartridge. I'm not sure which faucet you have but if it utilizes a ball, there is a retaining ring that is either grey or white that you have to tighten. If not, I would recommend contacting American Standard. You might have a bad cartridge or missed replacing another part. Sometimes they have small round washers at the back of the housing that need to be replaced as well.
Apr 01, 2009 | American Standard T375248.002 Polished...
Home Logo
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
