Question about Crate Music
I have a crate vtx 212 amp and the power comes on but none of the chanels comes on and no sound what so ever comes out. Nothing looks burnt or corroded idk what the problem is i need help lol
Posted by Trendkillbro's T.V. on
stynger007
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 33 Answers
Had the exact same problem, power light on rocker switch would illuminate no LEDs lit on overdrive, rythm or clean channels, effects led was dead as well. Having not used in awhile realized putting additional pressure on the power switch in the on position caused the LEDs to flash then go off. The skinny, the power rocker switch was illuminated but not allowing power to pass through to the amp itself. Removed power switch and sprayed with deoxit, reinstalled amp is now running loud and strong.
Posted on Mar 03, 2019
richie46
    Top Expert:
  • Crate Master
  • 12,962 Answers
If sure that power is reaching and getting into unit, then confirm that a signal is also reaching unit. If both are positive, then your gear is FUBAR if signal is going into correct input.
Posted on Feb 13, 2017
  • Trendkillbro's T.V.
    Trendkillbro's T.V. Feb 13, 2017
    Well this is the first time ive taken it apart and everything is connected. Ive checked everything. But when i plug it in and turn it on the light comes on on the power switch but thats it.
5 Related Answers
Mike Rogers
  • 11 Answers
SOURCE: turned on switch to crate V33-212 and it shorted out
Your amplifier is a solid-state rectified tube amplifier. This means that a tube is NOT used for the power supply. Why is this significant? Because most of the time you have the problem you are describing, it is because of the tube rectifier.
Since this amp does not have a tube rectifier, the problem is likely one or more of the tubes. I have seen in 95% of the amps I repaired that the tubes were the cause, and since the amp is so new, I would suspect tubes first.
Now the hard part: which tube? Without a tube tester, you will have to use the 'firewall' technique. You will need to get a bunch of replacement fuses, as you might go through a few untill you find the problem. Radio Shack is a great place for fuses (make sure they are SLOW BLOW type).
The problem is almost guarenteed to be the power tubes: they are a big failure mode in tube amps (the preamp tubes are not as likely the problem).
This is what I do at a customer site without a tube tester:
(1) Have either a KNOWN TO BE GOOD REPLACEMENT SET OF TUBES or a NEW SET OF TUBES.
(2) Have plenty of fuses.
(3) Start with power tubes: they cause most of these problems. Replace burned out fuse.
(4) Replace all 2 (or 4 in your case) with the good tubes.
(5) Turn on amp and play on it (30 minutes at various volumes and settings). Turn it on and off many times using the on/off procedure your amp requires (like using the standby switch on some models).
* if the amp plays and works, likely you had a bad power tube. If you are blowing fuses, the problem is either the power amp circuitry or the preamp tubes.
* Leave the good power tubes in before going on to the next step. Also: the minor difference in bias wont matter for what we are doing now: the bias being WAY out is almost never the cause.
(6) Check preamp tubes (easy to do, as this does not require us to poke around on the insides).
(7) Replace burned out fuse (atleast number two by this point).
(8) Replace all preamp tubes.
(9) Turn on and repeat step 5.
* Blowing fuses at this point means atleast two types of repairs needed: retention tube sockets or someone to look inside the amp. Either way, this is a serviceman repair (things I do). Since the amp is so new, take the warentee buyout and throw it back to where you got it. Crate is real good about dealing with these issues (if you are the only owner and it is within warantee).
If you need to contact warantee support, you can tell them you have had the amp re-tubed and the problem still persists (meaning they can brush you off with 'just get it retubed and then call us if there is problems'. This is like 'take two asprins and call me in the morning: 95% of all tube amp problems can be fixed by this (retube, not asprins).
If you have to do the warantee route, KEEP YOUR NEW TUBES. The preamp tubes are fine, but the power tubes may be damaged. Wait for what Crate tells you before you use them. This is if you are cheap. I would pitch all of the tubes and consider the 70 bucks as my cheap attempt to bet I am in the 95% solution number (tubes are the cause). Otherwise, the repair will cost shipping at a minumum. Dont you love it: tube amps are expensive and require someone with deep pockets to enjoy the tone. But what can we do: tubes DO sound better and when everything is working, they perform reasonably well.
Good luck on this!
-mike
Posted on Mar 30, 2009
Anonymous
  • 192 Answers
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Posted on Apr 19, 2009
soundchasr
Lawrence Nentwig
  • 11 Answers
SOURCE: NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Posted on Jul 25, 2009
Fred Yearian
  • 5603 Answers
SOURCE: I have a small crate rx15 solid state amp. The
Power light means very little. If unit has a preamp output, plug a set of headphones into it and see if you can hear anythin going through. (it will be weak). If you can, the power amp section is bad. Take in for service.
Posted on Mar 29, 2010
Fred Yearian
  • 5603 Answers
SOURCE: CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Posted on Sep 16, 2010
I just picked up a Crate VTX 212 amp. It sounds great! However, it hums a little louder than it should. I'm thinking it's a bad ground somewhere? Anyone out there deal with this before?
Check your guitar with another amp, or a different guitar with this one with no effects pedals, etc, to narrow it down to just the amp. At that point, try reversing the polarity. If none of the above helps, you may indeed have a bad ground somewhere and you'll need a tech to follow it to the source.
Aug 16, 2015 | Crate Music
Got a Crate VTX 15 guitar amp, and wondering if I can use a footswitch with it?
sure, why not, the footswitch connects between the guitar and the amp, with your guitar into the footswitch, go rock that thing!
Mar 10, 2013 | Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Fender hot rod deville 212 111. On the 2nd and 3rd distortion chanels the noise coming out of the speaker is very loud. Is this normal? Hard to play through the noise.
Hi. If the volume and drive levels are considerably low but you still hear a noise, you may want to consider trying a different guitar cable. The noise may be coming from a ground loop which is being amplified and overdriven by the amp itseld. I hope this helps. :-)
May 29, 2011 | Fender Musical Instruments Corporation...
Crate pa6fx powered mixer, powers on but when I hook speakers up to them, hear loud hissing and pops out of one of the speakers, nothing out of the other. I can hook up a mic and hear myself through the...
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
Dec 27, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
This is likely a power supply failure OR the amp chip is bad, It is probablly in the TDA family such as a TDA2050
May 15, 2010 | Music
I have a small crate rx15 solid state amp. The power light comes on, but no sound comes out of either the amp or headphone jack. No buzz etc....
Mar 29, 2010 | Crate Music
The effects do not work on my Crate VTX 350 H, what's wrong with it?
Are you getting sufficient power to the amp?
Could be a loose connection inside the amp (such as a wire), a bad component, or a severed ground. Many possibilities here. If you know electronics, take a multimeter and start testing all the components. Look for any burn marks, check for broken solder connections, and continuity test all wires. Be careful since amps can hold a deadly voltage for a good while. Be sure to drain the capacitors before doing anything else inside it. If you do not feel comfortable doing this, you can take it to a electronics repair person. Keep in mind that Crate is one of the harder amps to fix because most of their components are surface mount.
Nov 17, 2009 | Crate Music
I have a Crate PA-8 that hasn't been used in a long time. I destress and sing. Anyoo it has a power issue. Light is flashing on then goes off. I can't find a manual. Can anyone assist me please?
you have either a failing fuse or a failing power transformer. take out the screws on the top of the amp, leave the handle in tact and pull out the chasis. look at your fuse to see if it is in its holder correctly, and see if the fuse is burnt. the correct fuse values will be printed on the circuit board. if the fuse looks good then, it may be the power tranny going south.
May 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate bv120.no power or sound..no lights..f6 fuse has 160 ohms...
did you change out the fuse? could be a tranny going south. if you change the fuse and you still get no power, then you have a fried power transformer. they are relatively easy to replace. look on ebay . get the numbers off of the existing one and start web searching. something will come up. if not email me on my contacts tab in my website yostamplifier.com we can troubleshoot. you should see the custom blue voodoo i built and gave to my little brother.
Mar 14, 2009 | Crate Blackheart BH15H Handsome Devil...
Music Logo
665 people viewed this question
Top Crate Music Experts
Ngoro
Are you a Crate Music Expert? Answer questions, earn points and help others
